Pieman1410 Posted June 14, 2009 Report Share Posted June 14, 2009 Hi again, I don't know what all the types of cables are, e.t.c. cat5, cat5e, cat6, patch, crossover. I was just looking for some help to understand and pick the best cable to use for wired internet, (router-computer). Price doesn't really matter, as the most expensive cable i have seen wasn't really budget breaking. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
andsome Posted June 14, 2009 Report Share Posted June 14, 2009 Without any doubt Ethernet, if the computer will accept it. :D Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 14, 2009 Report Share Posted June 14, 2009 For standard router -> computer connection a CAT 5E patch cable is all you need - of a length suitable to you.No need to spend a lot but avoid the cheaper ones if you are thinking of doing a lot of connecting/disconnecting as the connector clips tend to become brittle and break after a lot of use.You must NOT use a crossover cable. This is for special computer to computer connection uses and will not work for the purposes you need.Wasn't a cable supplied with the router? Quote Link to comment Share on other sites More sharing options...
Pieman1410 Posted June 14, 2009 Author Report Share Posted June 14, 2009 I had a feeling a crossover was for connecting 2 computers, and one did come with it but its to small. Also, what is the difference between cat5e and cat6? is it just a perfomance upgrade? Thanks for the help Quote Link to comment Share on other sites More sharing options...
Boris Posted June 14, 2009 Report Share Posted June 14, 2009 Cat 6 - standard for Gigabit Ethernet and other network protocols that is backward compatible with Category 5/5e and Category 3 cables.http://en.wikipedia.org/wiki/Category_6_cableCat5ehttp://en.wikipedia.org/wiki/Category_5_cable#Category_5e Quote Link to comment Share on other sites More sharing options...
