HELP!!! USB Backup Drive: Can't Access!!&#33
Ok, I don't know what the heck happened...
I'm running Vista Home Premium(64bit).
I have a 1T USB external drive I am using for backup and storage. Been using it
for nearly a year with no problems. It has
about 150GB free space, so you can see I have a lot of stuff on
it that I would really hate to loose.
For some reason, I can no longer access the drive.
It comes up in Windows Explorer and shows the drive name as usual
as well as free and used space, but whatever I try to do with it, it hangs
and I loose communications with the OS. If I power it down, I can then
use the OS.
When I go to Computer Management/Storage/Disk Management it just sits
there, "Loading Disk Configuration Information". Nothing else comes up,
not even my C: drive!
In Device Manager, I can see the drive. Clicking on it it says the drive is
working properly. But on the "Volumes" tab, everything is blank.
If I go back to Windows Explorer it shows up with free and used space. If
I double click it, Windows Explorer says "Computer (Not Responding).
And weird things happen to the OS (Desktop goes blank or totally black).
The only way to recover is power cycle the problem drive.
At one time I was able to see all of the folders on the drive but when I
tried to access one, the problems above happened.
Is there way for me to low level reformat and save the contents of the drive?
Please let me know if you need more information.
Thanks,
Ray
use the OS.
Thanks,
Ray
Well, things have gone from bad to worse!!!
Seems the drive will not even spin up now!!!
Is it still possible for proper techs to recover data off the disk?
Ray
It used to be possible, but expensive. I feel sure there will be some outfit here :-
http://www.google.co.uk/search?hl=en&q...q=Data+recovery
Thanks.
I ended up taking it to Best Buy. $159.00 to recover ~600GB of data....
Looks like the drive itself was good but the mother board fried!!!
I probably could have taken the HD out and did it myself...
At least I'll have a spare 1TB drive to do something with????
I bought a Seagate external USB 1.5TB!!! ($149.00).....2 year warranty...
Ray
