kurt2 Posted August 28, 2009 Report Share Posted August 28, 2009 I want to move my installed programs, settings and personal files to a new computer (read different hardare) is this possible in windows.The old pc runs Vista but it needs ram and its not possible to upgrade. The new pc will be running Vista as well. Is it possible to make a ghost from one pc to another? Sorry if this is a dumb question, but I a linux guy. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted August 28, 2009 Report Share Posted August 28, 2009 http://www.clonezilla.org/ Quote Link to comment Share on other sites More sharing options...
kurt2 Posted August 30, 2009 Author Report Share Posted August 30, 2009 http://www.clonezilla.org/Thanks for the answer, but this limitation will be the end of it for this particular situation, but I will use it in the future.* Sysprep must not be used on upgrade installation types. Run Sysprep only on clean installations. Quote Link to comment Share on other sites More sharing options...
kurt2 Posted August 30, 2009 Author Report Share Posted August 30, 2009 If OS and programs are installed on the new pc. can I then move program settings, mail and so on to the new pc in an easy way like copying a few dirs? Quote Link to comment Share on other sites More sharing options...
-pops- Posted August 30, 2009 Report Share Posted August 30, 2009 I use a Belkin Easy Transfer Cable for transferring data from one machine to another. It works XP to Vista and Vista to Vista.There are other brands, including Microsoft. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted August 31, 2009 Report Share Posted August 31, 2009 There are other brands, including Microsoft.http://www.microsoft.com/windows/windows-v...y-transfer.aspx Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted August 31, 2009 Report Share Posted August 31, 2009 If you don't have a transfer cable, you could use an RAT?I was going to post Clonezilla but I was beaten :( Quote Link to comment Share on other sites More sharing options...
