charles88 Posted October 6, 2009 Report Share Posted October 6, 2009 Hi i have recently been putting my student films onto my laptop so i can burn them onto disk. they were quite big and when i deleted each one the space on my drive has gone back down but not back to the size it was before. it looks like about 6 gig has been added on is this normal?is it that all files leave a part behind if so is there any way to clear them fullythanks Quote Link to comment Share on other sites More sharing options...
Boris Posted October 6, 2009 Report Share Posted October 6, 2009 is it that all files leave a part behind... after deletion ? No :)What format were these films saved as ? .vob, .avi, .mp4 ??? Quote Link to comment Share on other sites More sharing options...
charles88 Posted October 6, 2009 Author Report Share Posted October 6, 2009 is it that all files leave a part behind... after deletion ? No :)What format were these films saved as ? .vob, .avi, .mp4 ???MPeg 2 i beleive i had to rup them off the dvds i had to make more copies using anydvd Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 7, 2009 Report Share Posted October 7, 2009 Did you delete them, or move to the Recycle Bin?Also, what is the file format of that partition? Quote Link to comment Share on other sites More sharing options...
charles88 Posted October 7, 2009 Author Report Share Posted October 7, 2009 Did you delete them, or move to the Recycle Bin?Also, what is the file format of that partition?tried putting in recycle bin but it said they were too big and will just perminantly delete them.sorry im pretty rubbish with computer what do u mean by file partition? it was the C drive Quote Link to comment Share on other sites More sharing options...
rong Posted October 7, 2009 Report Share Posted October 7, 2009 NTFS or fat32 Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 8, 2009 Report Share Posted October 8, 2009 tried putting in recycle bin but it said they were too big and will just perminantly delete them.Now here's a word I have never seen before :lol: (sorry!)I used to have a utility that showed a graph of all files on a partition; you could use this to see where your missing 6GB are. However, I cannot find it right now; I will post again later. Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted October 8, 2009 Report Share Posted October 8, 2009 Have they just disappeared from your recycle bin but not from the folder?To see this, go to C: then make sure you can see hidden files and folders and go in the RECYCLER folder. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 8, 2009 Report Share Posted October 8, 2009 Try JDiskReport - that should show you where your missing 6GB are.N.B. you need Java RTE installed in order to run JDiskReport. Quote Link to comment Share on other sites More sharing options...
