alocktbn Posted October 7, 2009 Report Share Posted October 7, 2009 Hi guys.. i want to ask about my wireless connection. question1: is there any software that can detect anyone using my wireless??i just need it so i can watch over for anyone who try to get a free internet connection from my wifi.question2: what is the best option for me to secure my wireless from being used by other person that i don't know? eg:my neighbor?? thanks guys............. i put my hope with you all Quote Link to comment Share on other sites More sharing options...
Boris Posted October 7, 2009 Report Share Posted October 7, 2009 Are you using WPA ?http://en.wikipedia.org/wiki/Wi-Fi_Protected_AccessYou can also limit the use of your wireless router to only those wi-fi appliances you specify, by quoting their MAC ids. Quote Link to comment Share on other sites More sharing options...
rong Posted October 7, 2009 Report Share Posted October 7, 2009 On my router you can hide the wireless signal so it can't be seen by others, I think you would have to change your WPA or WEP encryption and your user name and password if your neighbour has been using it though, Boris will know about that Quote Link to comment Share on other sites More sharing options...
alocktbn Posted October 8, 2009 Author Report Share Posted October 8, 2009 Are you using WPA ?i'm using WEP. Is that secure? there are 4 of us that using the wireless connection. but when i look at the DHCP client list, there are one unidentified client. with no Host name, MAC address --> 00:AB:00:00:00:00, IP 192.168.0.12is it mean there are other people connected to our wireless? Quote Link to comment Share on other sites More sharing options...
alocktbn Posted October 8, 2009 Author Report Share Posted October 8, 2009 http://en.wikipedia.org/wiki/Wi-Fi_Protected_AccessI do read it. its mean WPA is better. thanks.. Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted October 8, 2009 Report Share Posted October 8, 2009 Are you using WPA ?i'm using WEP. Is that secure? there are 4 of us that using the wireless connection. but when i look at the DHCP client list, there are one unidentified client. with no Host name, MAC address --> xxxxxxxxIP xxx.xxx.x.xis it mean there are other people connected to our wireless?Probably. But you may not wish to post that stuff on the internet. Another thing, if someone is using your router to use the internet, do you know how easy it is for them to also be looking at folders on your computer and possibly threatening your PC's health? Just a bit of a warning. Not trying to scare you. :PI'd also suggest limiting by Mac addresses. If you don't know how to do this, post the type of router you have and someone may be able to explain how to do this. Quote Link to comment Share on other sites More sharing options...
alocktbn Posted October 9, 2009 Author Report Share Posted October 9, 2009 there are 4 of us that using the wireless connection. but when i look at the DHCP client list, there are one unidentified client. with no Host name, MAC address --> xxxxxxxxIP xxx.xxx.x.xProbably. But you may not wish to post that stuff on the internet. that IP address and MAC address belong to the unidentified person. can it be used to damage my pc? i don't understand how the IP address actually work.. Quote Link to comment Share on other sites More sharing options...
dbruce Posted November 15, 2009 Report Share Posted November 15, 2009 there are 4 of us that using the wireless connection. but when i look at the DHCP client list, there are one unidentified client. with no Host name, MAC address --> xxxxxxxxIP xxx.xxx.x.xProbably. But you may not wish to post that stuff on the internet. that IP address and MAC address belong to the unidentified person. can it be used to damage my pc? i don't understand how the IP address actually work..A WEP key can be hacked in minutes. WPA V1 has also been compromised.....but the hacking it is relatively new. WPA V2 has not been compromised and is the most secure. If you are using WEP, that's the first thing that should change. Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted November 16, 2009 Report Share Posted November 16, 2009 They're all just as easy to crack as long as the person has the right resources. Quote Link to comment Share on other sites More sharing options...
