KidTDragon Posted December 24, 2009 Report Share Posted December 24, 2009 I just purchased a WNR3500 wireless router, and I'm having a hard time getting my chick's laptop to connect to it. It shows up on her wireless connection list, and we can get as far as the "Configuration in Progress" screen, but the "starting the registration process" bar will fill up twice and then say that it failed. Her laptop has an Intel PRO Wireless 3945ABG Wireless connector. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted December 24, 2009 Report Share Posted December 24, 2009 Is it detecting the encryption properly? And what operating system are we talking about here?All drivers installed properly? Quote Link to comment Share on other sites More sharing options...
KidTDragon Posted December 24, 2009 Author Report Share Posted December 24, 2009 Is it detecting the encryption properly?I think it is. I'm selecting WPA2-PSK [AES-CCMP] on the laptop and the router is set to use WPA-PSK [TKIP] + WPA2-PSK [AES].And what operating system are we talking about here?The laptop's running Windows XP.All drivers installed properly?As far as I can tell. It has no problem connecting to the unsecured wireless networks that it detects. Quote Link to comment Share on other sites More sharing options...
rong Posted December 24, 2009 Report Share Posted December 24, 2009 Is the router set to allow wireless connections? Quote Link to comment Share on other sites More sharing options...
KidTDragon Posted December 24, 2009 Author Report Share Posted December 24, 2009 Is the router set to allow wireless connections?It looks like it. I can't find any explicit on/off buttons, but as far as I can tell wireless is enabled. Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted December 24, 2009 Report Share Posted December 24, 2009 A wireless can be enabled with its green light or so but to actually enable it, you would need to go into the router's settings to take a look.If you don't know how to do this, do the following steps.Start > Run > cmd : ENTERipconfig /aCopy default gateway address into web browser's address bar as http://11.222.33.44Type in your password and stuff and find the wireless controls.See if that's the problem and let us know how you get on with that. Quote Link to comment Share on other sites More sharing options...
Boris Posted December 24, 2009 Report Share Posted December 24, 2009 Have you looked at the Setup Manual ?/>ftp://downloads.netgear.com/files/WNR3500_SM_26Nov07.pdf Quote Link to comment Share on other sites More sharing options...
KidTDragon Posted December 24, 2009 Author Report Share Posted December 24, 2009 A wireless can be enabled with its green light or so but to actually enable it, you would need to go into the router's settings to take a look.If you don't know how to do this, do the following steps.Start > Run > cmd : ENTERipconfig /aCopy default gateway address into web browser's address bar as http://11.222.33.44Type in your password and stuff and find the wireless controls.See if that's the problem and let us know how you get on with that.I went in the router's settings and everything looks fine there, I don't see anything that indicates that the wireless has been disabled.Have you looked at the Setup Manual ?/>ftp://downloads.netgear.com/files/WNR3500_SM_26Nov07.pdfYeah. Maybe I missed it, but I didn't see anything helpful in it. It seems to focus mainly on the wired side of things, which work fine.I've also tried connecting wirelessly with my Wii & PS3, and neither of those are able to connect either. I called Netgear's tech support, and they were only able to help me to a point, because my girl's laptop uses an Intel wireless card/interface and they only support Windows' wireless interface, which seems to be disabled and I couldn't figure out how to re-enable it.I'm starting to wonder if I have a defective router. Maybe I should just buy another one and see if it works out of the box. Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted December 24, 2009 Report Share Posted December 24, 2009 Do you mean where you go on the "View wireless signals in your area" window that Windows gives you but in turn, you're using another? If that is, you have to go to the Windows one and somewhere to the left or in the options is to re-enable the Windows software to manage your wireless connections. I can't say where exactly as I don't use Windows.But in all honesty, having a defective router could be a possibility. Could be a compatibility problem - I don't see why the tech support won't help you though - just means they're a bunch of idiots sitting around with their thumbs up it.Sorry I can't help much though.//--- Here, try these steps to making Windows manage the wireless networks and then see how it goes.It could be a problem where you have to manually go into the properties for the wireless using the Windows software and make sure it's using the same encryption as the router's.If all else fails, see if your router allows you to change from using WPA to WEP and then change it temporarily to see if you can connect using WEP. That may then tell you it's a WAP problem - if not, it's either the client-side or the router whining on that it's incompatible for some reason. Quote Link to comment Share on other sites More sharing options...
fmw Posted December 25, 2009 Report Share Posted December 25, 2009 I think it is. I'm selecting WPA2-PSK [AES-CCMP] on the laptop and the router is set to use WPA-PSK [TKIP] + WPA2-PSK [AES].Is the router using the same security scheme? Why not reconfigure the router to unsecured to verify that the computer will connect? If it does then you can fool around with security until things match. Another trick is to delete the connection in the computer, reboot, and start a new connection from scratch. Quote Link to comment Share on other sites More sharing options...
