Another small request....
Irene
I am really getting used to the new forum and like the general feel of it..... mostly, that is. :rolleyes:
The 'one/two' thing(s) which I really miss 'is/are', the small UP and DOWN buttons on each post.
I know that Ctl+home on the keyboard would usually take you to the beginning of the page.
However, in order to use that method on my keyboard, I would need to remove the numslock because the home key is on the same key as number 1. Since I regularly use the numeric keypad, it would make things really tricky.
Sorry, this looks like a long post for a small item.
Thank you in advance... :flowers: (Hopefully)
I too have more or less settled to the new layout. However I really feel that 'Todays active content' needs to be more noticeable. I very much doubt that newcomers will notice it. How about a button at the top? I would also query what use are the little red and green buttons, they NEVER work.smile.gif
  • 2 weeks later...
I very much like the new layout B)
Yes a button or if the link could be in bold then this would help.
So I see and it's the first time I've ever used the function :huh:
The above is exactly what I meant. There is also an embargo on smilies. If there are several in quoted posts then even ONE extra in the new post is not permitted.
