Second hard drive (partition) not being detected
Ruthy
Its Ok have managed to figure it out. It was a matter of selecting to unhide empty drives and then giving the drive a name.
The thing is before installing Windows i formated the second drive to NTFS as well, but i didn't think at the time that it would cause me to loose the data.
Is it easy/straight forward to recover the data? Or is it quite tricky/arquad?
Hi Ruthy.
I formatted a 500GB disk full of data the other week by mistake, and managed to get all the data back - no losses.
Very first thing, do not try to write any new files to the disk. Just leave that partition completely alone.
I used "Easeus File Recovery" others here have their favourites such as "RECUVA". I have never used that so cant comment. You are going to need free space somewhere other than the disk you are using to recover the data too. (External Hard Drive perhaps ?)
Easeus are doing their product for free at the moment. Download is **HERE**
I found that "Easeus" got all data back, and in the original folders. Other recovery software doesn't always do this.
Let us know how you get on.
John.
Good day
Have tried both Easeus and RECUVA. Since i haven't done anything to the drive since formating it, they both recoverd allot of data. But they both seem to be sorted quite randomly. I've looked through it and think it would take allot of time to get it all sorted out. So think am just gona leave it, suppose there wasn't anything overley important there that would justify hours of sifting.
Thank you for your help everyone, its really appreciated.
Good day
Thanks for the reply and feedback Ruthy.
I use Easeus "Pro" so it may be that the free version of the Easeus product doesn't do such a good job as the paid up version. :(
John.
