MagiCool Posted February 8, 2010 Report Share Posted February 8, 2010 Hi,Nice to meet you all!I am searching for an application that can monitor over the internet (not LAN) CPU usage, Bandwidth usage and RAM usage of a remote computer. So far all the applications I've tested presented some problems for my needs: works only on LAN, requires a Domain...Do you know any such applications?Thank You! Quote Link to comment Share on other sites More sharing options...
catgate Posted February 8, 2010 Report Share Posted February 8, 2010 Have you a specific programme in mind, perhaps? Quote Link to comment Share on other sites More sharing options...
MagiCool Posted February 8, 2010 Author Report Share Posted February 8, 2010 No. I guess it should be server/client to work. All I need is to monitor the CPU, Bandwidth and RAM usage in realtime from a remote location. I have to mention that the remote computer have Windows XP Home Edition. Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted February 9, 2010 Report Share Posted February 9, 2010 Hi MC, and Welcome.I have no problems at all monitoring CPU usage remotely by means of : *** Task Manager *** Bandwidth monitoring with: *** Bandwidth Meter *** (Free !)RAM Monitoring with: *** Meminfo *** (Free!)If you choose, you can also use: *** TeamViewer *** (Free!) the latest version includes, File Transfer both ways, Audio & Video functions, Re-booting of remote computer, Ctrl+Alt+Del to access Task manager.A whole bundle of stuff, - at no cost whatsoever. All, and any applications can be installed, and viewed on the remote computer, - Remotely. :) So far all the applications I've tested presented some problems for my needs.Why am I now getting this sinking feeling that you needs are going to be "One Off", and so diverse, complex, and enigmatic, that even Albert Einstein would hit his head against a wall in anguish ? John. Quote Link to comment Share on other sites More sharing options...
MagiCool Posted February 9, 2010 Author Report Share Posted February 9, 2010 Hi MANEMAN,It is quite simple. All the resource monitoring software that run on the remote computer are not accesible directly from another computer (only via VNC, TeamViewer etc). Accesing a remote computer with VNC fo example will alter the results, both CPU usage and Bandwidth usage. I need something like PMP - Remote Server Performance Monitor (http://www.eastbow.com/pmp/). Quote Link to comment Share on other sites More sharing options...
-pops- Posted February 9, 2010 Report Share Posted February 9, 2010 Am I misunderstanding this?I need something like PMP - Remote Server Performance Monitor (http://www.eastbow.com/pmp/)If you need something like the software you quoted, why not just use that?I am doubting the veracity of this problem. Quote Link to comment Share on other sites More sharing options...
MagiCool Posted February 9, 2010 Author Report Share Posted February 9, 2010 That software does everything I need except monitoring the bandwidth. It only shows %Network utilization (like windows task manager).I am doubting the veracity of this problem.Why is that? Am I missing something? Is this an easy problem to solve for you? Quote Link to comment Share on other sites More sharing options...
catgate Posted February 9, 2010 Report Share Posted February 9, 2010 Posted Yesterday, 19:34Have you a specific programme in mind, perhaps?I need something like PMP - Remote Server Performance Monitor (http://www.eastbow.com/pmp/).Why do you not get in touch with them and see if they can help you? ;) Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted February 9, 2010 Report Share Posted February 9, 2010 Aaaah ! I thought maybe it was so. A "Special Needs Client." I am always more than willing to spend time with them.And a bit of humour as I injected into my post always seems to brighten the day.I try to remind myself often when answering posts that I may well be dealing with a person who has "difficulties".I do hope the time I spent with you has furthered your development in social skills and the computing arena MC.Do as Catgate has suggested and contact: http://www.eastbow.com/pmp/ I am sure you will find them helpful and sympathetic towards you and your current difficulty.Good luck with your quest MagiCool, and take care my friend. Quote Link to comment Share on other sites More sharing options...
MagiCool Posted February 9, 2010 Author Report Share Posted February 9, 2010 Hi,Their reply:"....However, you may want to monitor the bandwidth value directly. Unfortunately, PMP is not ready for that. I think it will take much times to be applied because we need to change the agent and admin, including alert logic, interface too.Sorry that I can't provide the version that you want at this time."So this is not an option :( Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted February 9, 2010 Report Share Posted February 9, 2010 Hi MC,It does rather sound as though you are a little bit stuck for the time being.End of the line ? Or do you wish to take the bull by the horns, escape forums, and find an answer ?I would suggest that you continue to use a search engine/s to track down that which you believe to be available.I will return to an earlier of your quotes:Am I missing something?A revealing question on your part perhaps ?Although the question was pointed towards "Pops", it could well be the question you should fully investigate (Perhaps with the aid of Google or a similar search engine)Open Source software authors are usually very helpful. (I will not guide you, but let you find your own pathway)Your native country (Romania) is not usually viewed as the most sympathetic towards people with problems, however with internet access you should have no problems contacting people such as this: *** Processing Deficits *** Posting your query on one of their forums may well be fruitful for you.Answers to personal, or computing problems can come about in the most unlikely of places. - Try it. :)Break free, - live your life in a manner of self sufficiency without total reliance on others. You will then feel the growth start to take place within you. John. Quote Link to comment Share on other sites More sharing options...
