scroll bar problem need help
amb
i'm having an issue where when i scroll in any window just to the left of the scroll bar one of my files/folders shows up in a little box when i scroll up/down the items in this little box scroll to and it's starting to piss me off anyone know how i got this on here and how i can remove it. cheers
This could be something to do with your mouse or keyboard software. It's certainly not a feature of XP, but I don't know about Vista or Windows 7.
Does it occur in both Internet Explorer and Windows Explorer (the service that controls browsing within your own files when not accessing the internet)?
Can you right-click the box or folder - if so, is there a Properties option?
I suggest you do a little experimenting. What file/folder names show up in the little box? Is it the one you are looking at, the next one up, the next one down, or is it a file/folder completely unrelated?
Also, have you tried doing a System Restore to a time before this annoyance started? That often solves a lot of these sorts of problems.
