tav0037 Posted September 7, 2003 Report Share Posted September 7, 2003 On sisters pc, when switch on , get a blue screen, saying windows is shutting down to prevent damage & mention something about "unbootable" & gives some values , eg 000000000, 0000000001 etc. :( Can anyome tell me if this is a windows fault or PC fault & will XP need to be re-installed.Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 7, 2003 Report Share Posted September 7, 2003 Can you post the full error message?Could it be 'unmountable' rather than 'unbootable' ?Can you open up the PC and check all the cables are securely in place? Quote Link to comment Share on other sites More sharing options...
Chris Posted September 7, 2003 Report Share Posted September 7, 2003 Click this please ""STOP 0x000000ED UNMOUNTABLE_BOOT_VOLUME" Error Message When You Restart Your Computer or Upgrade to Windows XP"Does the above look like the message?If you could write down the whole messsage no matter how long or complicated and post it back. Quote Link to comment Share on other sites More sharing options...
tav0037 Posted September 7, 2003 Author Report Share Posted September 7, 2003 Yes .... it is "Unmountable boot volume". Will post the full message when I return.Thanks Quote Link to comment Share on other sites More sharing options...
tav0037 Posted September 7, 2003 Author Report Share Posted September 7, 2003 Got this over the phone.A problem has occurred.Unmountable_boot_volumeif problem occurs, disable any newly installed hard/software.Disable biomemory options such as caching or shadowing.If you need to , Safe Mode to remove/disable components.Restart computer, press F8 to select Advance Start-up option & select Safe Mode.STOP: 0X000000ED (0X80E95920, 0XC0000032, 0X00000000, 0X00000000) ------------------------------------When rebooting using Safe Mode or any mode after pressing F8, this screen appears almost immediately& the only thing I can do is reboot ...... straight back to the blue screen.Thanks .Shaun :rolleyes: Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted September 7, 2003 Report Share Posted September 7, 2003 have a look here http://www.ltcom.com/page/FAQ/STOP%20Messa...P%20Upgrade.htm was this a upgrade to xp? Quote Link to comment Share on other sites More sharing options...
tav0037 Posted September 7, 2003 Author Report Share Posted September 7, 2003 It wasnt an upgrade ... came with XP when bought pc.btw ellas ........ browser coulnt find the link :( Quote Link to comment Share on other sites More sharing options...
Chris Posted September 7, 2003 Report Share Posted September 7, 2003 http://support.microsoft.com/?kbid=297185 Quote Link to comment Share on other sites More sharing options...
tav0037 Posted September 7, 2003 Author Report Share Posted September 7, 2003 A big THANK YOU to everyone for your help ...... now got to visit sister to see if anything can be done.Thanks again :D Shaun Quote Link to comment Share on other sites More sharing options...
