Captain Dan Posted March 14, 2010 Report Share Posted March 14, 2010 I've had my laptop for a few months now, and it came packaged with a bunch of software I've never had to pay attention to. One time, I logged into my profile, and Registry Mechanic appeared on my Desktop as a shortcut. I looked it up online and thought it might be useful, so I tried to run it. When I did, it just immediately stopped working, and my computer can't find a solution, or so it seems. Does this program really help, or should I just ignore it? Quote Link to comment Share on other sites More sharing options...
Boris Posted March 14, 2010 Report Share Posted March 14, 2010 The full version of Registry Mechanic has a one year license.It was probably a trial version on your machine - which has now expired ? Quote Link to comment Share on other sites More sharing options...
-pops- Posted March 14, 2010 Report Share Posted March 14, 2010 There is a lot said about registry checking software - a lot of it is rubbish just trying to sell unnecessary things to fill up your hard drive.I've been using Windows since its early days and never found a need for a registry cleaner. If you do want to use one, try Ccleaner http://www.piriform.com/ccleaner/download which is free and has a lot more useful things in it than merely cleaning up the registry. Quote Link to comment Share on other sites More sharing options...
Captain Dan Posted March 14, 2010 Author Report Share Posted March 14, 2010 Okay thanks. I won't worry about it. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 15, 2010 Report Share Posted March 15, 2010 I've had my laptop for a few months now, and it came packaged with a bunch of software ...The solution: http://www.pcdecrapifier.com/ Quote Link to comment Share on other sites More sharing options...
andsome Posted March 15, 2010 Report Share Posted March 15, 2010 Registry mechanic is a definate NO NO. Quote Link to comment Share on other sites More sharing options...
