Windows 7 Pro strange problem
Azdian
getting problems also with games ( Counter Strike source )
see picture
/>http://img6.imageshack.us/img6/8123/dedust20001fr.jpg
anyhow .. someone of my friends told me that i face this problem cause i have an OEM windows version on a customized PC
and i should upgrade to x64 retail
i don't know guys .. im really confused :(
I just looked at your link/screenshot in your earlier post.Is that half the screen showing?And are those palm fronds in the foreground?Or is all that tearing?
I would suspect a faulty GPU or memory the culprit if this is video tearing that is shown....
Have you tried adjusting you screen refresh rate to a higher Hz?
Can you adjust the clock rate on your graphics card?
Azdian,have you installed chip set drivers from your motherboard's site?--->http://www.gigabyte-usa.com/Support/Motherboard/Driver_Model.aspx?ProductID=3247
Also,-if you haven't yet-run Windows Experience Index tool.--->Start>Control Panel>All Control Panel Items>Performance Information and Tools>either Run the assessment or the equivalent thereof.
For some arcane reason,this should be run after a fresh installation of Windows.(It is supposed to "link" all of your hardware together and gives Windows a new home [marking these hardware components as it's native environment as it does]).
Also,follow the path highlighted in the screenshot below and select circled content.This will give you a general system health report.
