Missing hard drive driver
Hello all, first time post.
To make a long story short, I accidentally uninstalled the driver for my hard drive in Windows XP, and now (surprise) Windows will not boot. I am hoping there is a way to reinstall the driver from outside of Windows, or at least a way to install some kind of driver that will allow Windows to boot and correct the problem.
Can anyone help? Let me know if more information is needed. Thanks in advance.
I am mystified by this problem.
Hard drive drivers are nothing to do with Windows but are a function of the BIOS (CMOS) of your computer. Am I correct in thinking that there have been some "adjustments" made to the BIOS which didn't go quite according to plan?
pops, I did not understand either - I thought the problem might be missing ntldr, but when I googled for hard drive 'drivers', the computerhope page came up, so I passed it on. will be interested to learn more :)
Ok, here are more details.
I was busy playing with my Android phone, mainly trying to get Windows to recognize it. As a result, I was installing and uninstalling drivers a bunch. Then, I saw something in my Android book that looked just like the hard drive driver (unknown to me at the time), so I uninstalled that too. Then it asked me to restart, which I did, realizing too late what I thought I had done, and now it barely gets to the Windows loading screen before it bluescreens.
So my initial assumption is that I uninstalled the Windows driver for the hard drive, so that even though the BIOS knows what to do with the hard drive, Windows has no idea.
Am I completely off? I'm hoping this is a simple matter of somehow reinstalling the driver.
Wait, I might be wrong. I might be remembering incorrectly.
I went into the Device Manager and "removed" the hard drive there. So it may be that uninstalled the "device" rather than the "driver". I don't have any other WinXP machines, so I can't be sure.
First thing to try: boot into Last Known Good Configuration.
If that does not fix it, try booting into Safe Mode and do a System Restore (to a date before you created the problem) in there.
That should do it.
I totally missed the "Last Known Good Configuration" option. I tried that and it booted right up. +1!
What I did was I went into the device manager and "accidentally" clicked "Uninstall" for my hard drive, then when it rebooted, it failed, and then "Last Known Good Configuration" rolled back the problem. Thanks!
Can you not reinstall Windows?:)
That's a bit drastic, to repair one little accident.
Probably true, but before I started using ACRONIS and keeping mirror images to install, I more often than not found that messing about with repairs resulted in more problems. A clean reinstall if in doubt never failed, and was easier in the long run.B)
Reinstalling Windows (clean or repair install) was a routine job in the Windows 9x days. However, I have never (ever) found it necessary to reinstall an NT-based Windows system (NT4, 2K, XP, or newer).
But of course you are right: the best thing is to always have a good backup.
