andsome Posted May 11, 2011 Report Share Posted May 11, 2011 I have just answered a P.M. from another forum member. I needed to alter a word. When I created a cursor after the word I wanted to change, the box went white. It took about thirty or forty seconds to revert. This happened every time that I wanted to change something. We seem to have a problem. Quote Link to comment Share on other sites More sharing options...
bludgard Posted May 11, 2011 Report Share Posted May 11, 2011 I have just answered a P.M. from another forum member. I needed to alter a word. When I created a cursor after the word I wanted to change, the box went white. It took about thirty or forty seconds to revert. This happened every time that I wanted to change something. We seem to have a problem.So it is you who is the incorrigible Dubaian spammer?:D Quote Link to comment Share on other sites More sharing options...
andsome Posted May 11, 2011 Author Report Share Posted May 11, 2011 I have just answered a P.M. from another forum member. I needed to alter a word. When I created a cursor after the word I wanted to change, the box went white. It took about thirty or forty seconds to revert. This happened every time that I wanted to change something. We seem to have a problem.So it is you who is the incorrigible Dubaian spammer?:DI will send you a P.M. When you click on answer, try to create a cursor to alter a word, and see if it does the same for you.:) Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 12, 2011 Report Share Posted May 12, 2011 Sorry, I cannot understand the term "creating a cursor". Do you mean placing the cursor at a certain position, or selecting a section of text?P.S. moving the topic into the forum discussions forum. Quote Link to comment Share on other sites More sharing options...
andsome Posted May 12, 2011 Author Report Share Posted May 12, 2011 Sorry, I cannot understand the term "creating a cursor". Do you mean placing the cursor at a certain position, or selecting a section of text?P.S. moving the topic into the forum discussions forum.When I want to edit while making a reply to a PM, I left click to the right of the text that i want to change, then back space to remove the text before typing in the replacement text.. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted May 12, 2011 Report Share Posted May 12, 2011 I have just tried what you do andsome and have had no problems. Quote Link to comment Share on other sites More sharing options...
andsome Posted May 12, 2011 Author Report Share Posted May 12, 2011 I replied twice to a PM from bludgard. Using ordinary reply the same problem occured, using fast reply there was no problem. Were you replying to a PM? Quote Link to comment Share on other sites More sharing options...
bludgard Posted May 12, 2011 Report Share Posted May 12, 2011 I have just answered a P.M. from another forum member. I needed to alter a word. When I created a cursor after the word I wanted to change, the box went white. It took about thirty or forty seconds to revert. This happened every time that I wanted to change something. We seem to have a problem.So it is you who is the incorrigible Dubaian spammer?:DI will send you a P.M. When you click on answer, try to create a cursor to alter a word, and see if it does the same for you.:)I haver run into these issues with any corrective attempts or "cursors" going askew. I think you are quite batty, old chap.. I do have problems with copying and pasting in an "active" window within IE8. I usually have to highlight the content and use IE Page options to copy and paste. I haven't tried this with any other browser lately. IE9 doesn't share this problem. Niether does IE7 or 6.I would report the bug but it just might be you and I that experience these inconvienances. So be it. I will conquor. As soon as I learn how to spell.:lol: I'll report back on this one, ansome. I need a nap.B) Quote Link to comment Share on other sites More sharing options...
andsome Posted May 12, 2011 Author Report Share Posted May 12, 2011 This has only just occured, and ONLY on this forum. Quote Link to comment Share on other sites More sharing options...
bludgard Posted May 12, 2011 Report Share Posted May 12, 2011 This has only just occured, and ONLY on this forum.Yes. Only on this forum do I have the problem as well. Quote Link to comment Share on other sites More sharing options...
andsome Posted May 12, 2011 Author Report Share Posted May 12, 2011 This has only just occured, and ONLY on this forum.Yes. Only on this forum do I have the problem as well.Thank goodness it's a fault, and nothing that I am doing.B) B) B) B) Quote Link to comment Share on other sites More sharing options...
