aimee-mary Posted December 28, 2011 Report Share Posted December 28, 2011 I have a dell laptop running windows 7 and it started to basically freeze and I couldn't close any programmes or shut it down properly.So, I forced shut it down and then when I came to start it up again it wouldn't load windows.It comes up with the dell start up screen and then goes to a black screen with a white flashing line in the top left corner, and the only thing I can do it go to the set up menu Or press ctrl alt dlt which just starts the whole process all over again! Does anybody know how to fix this? And if so, will I loose files? Thanks in advance to anyone who can help :) Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted December 29, 2011 Report Share Posted December 29, 2011 Can you boot into Safe Mode or Last Known Good Configuration? If so, make a backup of all your files, then reinstall or repair Windows. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted December 29, 2011 Report Share Posted December 29, 2011 1Turn on the Dell laptop.2Repeatedly start tapping the F8 key on the keyboard. If the F8 doesn't work for some reason, you will need to restart the computer and repeatedly tap the F5 key until the screen changes.3Look at the screen that loads. You will see different options. Use the down arrow to highlight "Safe Mode," press enter on the keyboard or enter the number on the keyboard that is associated with the safe mode option. That number will be on the left side of the list.4Allow the computer to boot in safe mode. The screen will look different from what you are used to seeing. Quote Link to comment Share on other sites More sharing options...
aimee-mary Posted December 29, 2011 Author Report Share Posted December 29, 2011 I've tried repeatedly tapping f5 and then f8 but I can't get my laptop into safe mode :s Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted December 29, 2011 Report Share Posted December 29, 2011 Is the laptop still under warranty?. Quote Link to comment Share on other sites More sharing options...
aimee-mary Posted December 29, 2011 Author Report Share Posted December 29, 2011 No it isn't :( iv tried booting it from the windows disc and then tried to do a repair but that doesn't work, and when I try to reinstall windows it just doesn't make any progress. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted December 29, 2011 Report Share Posted December 29, 2011 What is the Dell model number, and when you say you booted from the Windows disk, was that a back up you made when you first had the laptop, or was it a supplied OEM disk?. Quote Link to comment Share on other sites More sharing options...
aimee-mary Posted December 30, 2011 Author Report Share Posted December 30, 2011 I've managed to get the laptop working again, i tried all the suggestions that i had from numerous people to try and save some of my documents but I ended up eventually reinstalling windows 7 (when it decided to work) because nothing else was working.So now I'm pretty sure I've lost all of my files. Is there any way for me to get them back at all? Thankyou for all of your help! Quote Link to comment Share on other sites More sharing options...
bludgard Posted December 30, 2011 Report Share Posted December 30, 2011 I've managed to get the laptop working again, I ended up eventually reinstalling windows 7 ....So now I'm pretty sure I've lost all of my files. Is there any way for me to get them back at all? I would suspect that your gut instinct is dependable.However, if data was stored on a sparate partition (other than Windows' drive), the chances of recovery are greatly incresed. One may be able to recover the data anyway if it hasn't been overwritten by the fresh install.One would need a drive as a repository for the data to be extracted to. The capacity of the drive would depend on the quantity of data. Quote Link to comment Share on other sites More sharing options...
Irene Posted December 30, 2011 Report Share Posted December 30, 2011 Maybe something useful in the following link:http://support.euro....0&isLegacy=true Quote Link to comment Share on other sites More sharing options...
