mav3 Posted May 23, 2012 Report Share Posted May 23, 2012 hi im trying to make my own computer for the first time. my budget is around £400, the PC that im trying to achieve would be mainly use for gaming purposes such as running Diablo3 and World of Warcraft.after long hours of planning and searching the web i came up with this spec:http://pcpartpicker.com/uk/p/8H1xand this would be the case for it and PSU:http://www.ebuyer.co...-rc-330-kkpl-gpthere are few things i would like to know:1. are they all compatible? will they work well?2. shall i look for another motherboard? or this one is ok?3. can i run a 64bit Window 7 on this build?4. for obvious reason can i run diablo 3 at high setting?5.am i better off buying this http://www.ebay.co.u...#ht_2534wt_11876. lastly, any recommended build out there worth £400 lessAll Comments would be highly appreciated.Thank you Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 24, 2012 Report Share Posted May 24, 2012 Why have a micro ATX motherboard in a full size (ATX) case?The motherboard does seem low cost. You might be better investing more money in that.Building your own computer doesn't necessarily save money - it may do the opposite - but nothing quite beats the sense of satisfaction when you plug in and it springs into life (or not!). Even if it doesn't go first time, it's very interesting to sort the problem(s) out.If you're thinking of buying a pre-built machine, go for a well known brand or, better, a local builder, rather than an unknown maker. Quote Link to comment Share on other sites More sharing options...
WastedTalent Posted June 10, 2012 Report Share Posted June 10, 2012 Why have a micro ATX motherboard in a full size (ATX) case?The motherboard does seem low cost. You might be better investing more money in that.Building your own computer doesn't necessarily save money - it may do the opposite - but nothing quite beats the sense of satisfaction when you plug in and it springs into life (or not!). Even if it doesn't go first time, it's very interesting to sort the problem(s) out.If you're thinking of buying a pre-built machine, go for a well known brand or, better, a local builder, rather than an unknown maker.I 100% agree. I had a custom built pc. $2000. Did not include a monitor, keyboard, mouse, anything. That was just the case and all the guts. Along with Windows 7. Building your own, can lead to a bigger cost. Pre-built will more than likely make you sacrifice features or specs but will keep the cost down. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 11, 2012 Report Share Posted June 11, 2012 On looking at the pre-built one, the graphics card will not allow you to have all the bells and whistles on, it is not powerful enough.Of the parts you have selected, I have to agree with pops, invest a bit more money in a better motherboard.Take a look at some thing like this, http://www.expertreviews.co.uk/motherboards/1290406/asus-p8z68-v-lx Quote Link to comment Share on other sites More sharing options...
