oldtee Posted September 24, 2012 Report Share Posted September 24, 2012 New bee here. Patience requested.Windows 7new HP console typeI have noticed an increase in system freezes when visiting some web sites. For instance I go into Huffingtonpost and sometimes when I open one of the panes (sub topics) the system freezes. I cannot close the topic, the site, and the sliders don't work.When I do a 'cntl alt del' the task says it is running. I have more or less traced it to explorer. Pretty sure it is explorer 8. May have to do with pop ups or just poor web site design.I am a novice. Help is appreciated.JL Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 24, 2012 Report Share Posted September 24, 2012 If you are on IE8, update/upgrade to IE9/>http://windows.microsoft.com/en-GB/internet-explorer/products/ie/home Quote Link to comment Share on other sites More sharing options...
oldtee Posted September 24, 2012 Author Report Share Posted September 24, 2012 My system is up to date with the latest software releases to windows, including ie9.Incidently, this site locked up. I am probably wrong, but it may have something to do with the popup blocker At the moment it is off.I have a Dell lap top that I am trying to trouble shoot. It has the same problem. I wonder if I am alone or are othes having problems with explorer. I paid for extended Dell support only to find out I had to buy a Windows OS disk (one did not come with the computer) so they can reload windows. They spent hours with me and ran every free repair program known to man (I suspect) only to come up empty. No viruses, no problems, just a lot of time. You are a moderator, thus a knowledgable person and advice I get from experts is to use Chrome or Fire something which is not good advice for novice users who depend on ms products and support and keep systems up to date. I would love to solve this problem once and for all.My problems started on both systems after the last Windows updates. The lap top had been on the shelf for two months and took a lot of updating and at first I thought that was the trouble but then it started on this system, a HP which is only 3 months old.I ramble, sorry.'JAL Quote Link to comment Share on other sites More sharing options...
oldtee Posted September 24, 2012 Author Report Share Posted September 24, 2012 If you are on IE8, update/upgrade to IE9http://windows.micro...roducts/ie/homeThis is a good site, thanks.Ran scan, no problems.Incidentaly, the problem is repeatable. How do you capture an error report to send to MS?JAL Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted September 24, 2012 Report Share Posted September 24, 2012 oldtee, you may find this helpful./>http://windows.microsoft.com/en-US/windows7/How-do-I-use-Problem-Steps-Recorder Quote Link to comment Share on other sites More sharing options...
oldtee Posted September 25, 2012 Author Report Share Posted September 25, 2012 Thanks. Now to figure out who to send the data to. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 26, 2012 Report Share Posted September 26, 2012 Is your Windows 7 64-bit or 32-bit edition?Do you use IE9 32-bit or 64-bit edition?Can you post a link to the site where the problem occurs?Does that problem page use Flash? Quote Link to comment Share on other sites More sharing options...
oldtee Posted September 26, 2012 Author Report Share Posted September 26, 2012 I should have updated the situation yesterday. To make a long story short, problem went away with the installation of Explorer 8. Which websites is unimportant, it would happen with any site, even this one.Dell gets a minus so far. Lap top still has issues but I am able to browse with Chrome. Also they charged me twice for the Windows disk. :(HP gets a plus. Tower is up and running well..Why should I care if a Web site uses flash? It is their job to deliver content that works. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 27, 2012 Report Share Posted September 27, 2012 Why should I care if a Web site uses flash? It is their job to deliver content that works.Not if the software is incorrectly/incompletely installed on your computer(s). Quote Link to comment Share on other sites More sharing options...
bludgard Posted September 27, 2012 Report Share Posted September 27, 2012 Sure sounds like software issues to me. Have you opened Task Manager or Resource Monitor to check CPU, RAM and disk usage?The machine is not being bottle-necked by a power saving scheme such as the type provided by Windows and/or possibly BIOS? Quote Link to comment Share on other sites More sharing options...
gasonlewis Posted October 3, 2012 Report Share Posted October 3, 2012 How fast is your net connection? Quote Link to comment Share on other sites More sharing options...
