Problem in win 7
demolishy
Hello.
So here is the problem.
Whenever i play a game, watch a movie or do something actually i dont have do to anything there is a thing that keeps appearing every 2 minutes or so and it always goes to desktop if it appears. It is getting really annoyng.
Here is a picture.
/>http://imageshack.us/f/547/nimeta.png/
Need help removing it
Thanks.
Looks a bit like a Santa Claus face ????
It is almost impossible to help you remove it if we don't know what it is :(
Do you have up to date Anti-virus on this machine ? - and have you scanned it for malware ?
What make/model of PC is it ?
What Operating System - it looks like Vista/Win 7 ?????
If it has only started happening recently, try doing a System restore back to a point before it started ?
Thanks Boris.
The link previous, sort of dangerously solved the problem, but thinking about it further, I would not suggest turning off any services without first checking what you are turning off,- and why.
Some amateur websites fall short of answering those questions. I wont be going there again.
I would prefer to go to the MSDN blog where Boris solved the problem for us and find the whys?, wheres ?, and fuller explanations as to what exactly is going on:
