Alan2273 Posted January 11, 2014 Report Share Posted January 11, 2014 This is one I have not come across before.I was given a Compaq Presario C504EA that needed the drive wiping of personal information and to do what I liked with it afterwards, ( I am giving it to a local charity, if I can sort this problem out).I have reinstalled Vista with all the service packs and updates, ( it took nearly 2 days), then I noticed the clock was loosing time, so I reset it and an hour later it had lost time again.I have changed the CMOS battery, thinking that was the problem, but if the laptop is switched on or off it still loses time. Can anyone suggest what the problem might be. Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 12, 2014 Report Share Posted January 12, 2014 I don't know if it's the same now but those CMOS batteries used to be very unreliable and often you could get a dud. Have you tried another one? Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted January 12, 2014 Author Report Share Posted January 12, 2014 I checked the battery with a multimeter, and it read 3.35V, so just to be sure I put another one in and still the same problem. It is set to the correct time zone, GMT London. Quote Link to comment Share on other sites More sharing options...
andsome Posted January 12, 2014 Report Share Posted January 12, 2014 Could be a daft question. Is the machine set to update to internet time automatically? Probably is a daft question, just trying to be helpful. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Not a daft question at all Keith, but it is set up to update automatically. I have not solved the problem, which is to do with a Vista update, (don't you just love Microsoft), but I have found a way to work around it with a 1999 time script and a batch file. Quote Link to comment Share on other sites More sharing options...
