johnoo Posted April 6, 2015 Report Share Posted April 6, 2015 The solution centre on my Lenovo Think Centre Edge 72 says that the Intel Management Engine Interface has been disabled due to a code 43 problem.I have clicked right onto the I/face & ensured the latest Driver is installed, & it is.The message says that the fault is not critical but:-1 Does it matter?2 How can I correct the problem? (Assuming it's easy) Quote Link to comment Share on other sites More sharing options...
-pops- Posted April 6, 2015 Report Share Posted April 6, 2015 Code 43 errors are explained in Google. https://www.google.co.uk/?gfe_rd=cr&ei=GfUHVPKDEMKq8we0r4HIBg#safe=off&q=code+43 Quote Link to comment Share on other sites More sharing options...
johnoo Posted April 6, 2015 Author Report Share Posted April 6, 2015 Yes, looks to be a generic fault code.I undertook a restart & I think the problem is cured. Quote Link to comment Share on other sites More sharing options...
