Damo Posted October 9, 2003 Report Share Posted October 9, 2003 Can a windows 98 SE Upgrade Disc be used to do a clean install on an empty machine? Quote Link to comment Share on other sites More sharing options...
Guest Posted October 9, 2003 Report Share Posted October 9, 2003 yes, providing you have the win95 disk available when the install routine asks for it. Quote Link to comment Share on other sites More sharing options...
moon Posted October 10, 2003 Report Share Posted October 10, 2003 Didn't work fo me. I had to load the 98 disk ( in my case) first before 98SE would load. Mine is a 98SE Upgrade. Quote Link to comment Share on other sites More sharing options...
andsome Posted October 10, 2003 Report Share Posted October 10, 2003 As far as I can see it will not contain all the files, if it is only an upgrade disc. Quote Link to comment Share on other sites More sharing options...
Tony Posted October 11, 2003 Report Share Posted October 11, 2003 As Morpheus saysJust start the setup as you normally would, then a couple of mins into it, it will ask you to insert your Win 95 or Win 98 Full version disks for a validity check.Once you put the disk in it will take a few seconds and then ask you to put the Win 98 Se disk back in, then the installation will carry on and you will have the FULL install of 98se on your system.All the bestTony Quote Link to comment Share on other sites More sharing options...
Damo Posted October 12, 2003 Author Report Share Posted October 12, 2003 Thanks for the replys folks!BIGGER Thanks to Nellie though!!! ;) Quote Link to comment Share on other sites More sharing options...
