Hardware Without Driver......problems?
Damo
I've been sorting out a friends pc, including changing cd drives, putting new memory in ...so on.....
He had a lot of crashes and slowdowns and he couldn't figure it out!
Then I saw he had a PCI internal Modem, which had no drivers installed on it, as he has Bband I took it out.
All seems to be running fine now, but could that have been one of the reasons for the crashes and lock ups?? I know in device manager it had the ol' yellow exclamation point next to it........but not anymore...now that its out!!!
As you can see my speciallity is not hardware!!! :P
cheerz
Damo
All was well when I took the modem out, I reinstalled the OS aswell. I had it running for 5 hours without a problem.
Then he took it home, plugged all HIS stuff into it and suddenly it wouldn't boot up, just hung on the splash screen.
We went through a few options on the phone, I told him to take his mouse out and try booting without it....it worked fine.......so....now I'm even more confused! Surely a mouse (ps2) couldnt bring a system to a stand still.........could it?
Guest nellie2
If you are going to do that then don't forget to check the bios settings, depending on the bios you sometimes have to turn on the option to use a USB mouse and keyboard.
At least on my old mobo you do.... as I found out after about two days of wondering why my new USB mouse wouldn't work in the USB slot!!! :blush:
Yeah, Im gonna lend him my USB mouse tomorrow, the only puzzling thing is, is that it used to be my PC and I never had a problem with it, i always used a USB mouse. Its ever since he's had it there have been problems!
Thats why I never usually sell anything to friends at work! Because I just fel obligated to fix it, even though it was fine when i sold it to him!
GAH!!!
Guest nellie2
When I was having my probs with my other system and xp.... the nice man from Microsoft said that if I was having total system lock ups. Meaning that even Ctrl-alt-del didn't work, no keyboard and no mouse... nothing, then you can safely say it is a hardware problem. ( He did give me a lot of technical detail and I must have made the right noises in the right places because he went of for ages..... but I'm afraid all that info has fallen out of my head!! :( ).
If, however the system is locking up, but you can do Ctrl-alt-del then it may be a software problem.............. WHAT IS HE LOADING ON THE MACHINE???
I had a similar problem recently, mouse plugged in, wouldn't boot, someone else was going to look at it, after 2mths I got my hands on it again opened it up, pressed on all the plugs inside. Not given any probs since, all hardware still the same !!
