johnoo Posted May 2, 2020 Report Share Posted May 2, 2020 I used to use C Cleaner before installing Windows 10. But for some reason on installation of Win. 10 I uninstalled C Cleaner. So question is with Win 10 is CC Cleaner worth using as a free version? Quote Link to comment Share on other sites More sharing options...
Boris Posted May 2, 2020 Report Share Posted May 2, 2020 I'm still using it - it has its uses ? Quote Link to comment Share on other sites More sharing options...
johnoo Posted May 2, 2020 Author Report Share Posted May 2, 2020 OK, thanks, to expand, I use MWB weekly & run AVG as security so still good to use C Cleaner? Also are there any conflicts with Windows 10? Quote Link to comment Share on other sites More sharing options...
Boris Posted May 2, 2020 Report Share Posted May 2, 2020 5 hours ago, johnoo said: OK, thanks, to expand, I use MWB weekly & run AVG as security so still good to use C Cleaner? YES Also are there any conflicts with Windows 10? NO Quote Link to comment Share on other sites More sharing options...
johnoo Posted May 2, 2020 Author Report Share Posted May 2, 2020 I've been reading this article which advises not to use C Cleaner, & i don't want to give myself any more problems, so what do you think? https://helpdeskgeek.com/free-tools-review/why-you-shouldnt-download-ccleaner-for-windows-anymore/ Quote Link to comment Share on other sites More sharing options...
Boris Posted May 2, 2020 Report Share Posted May 2, 2020 Any views are always slanted towards the view of whoever writes them. I use 4 different browsers and the main thing I like about CCleaner is that (unlike the individual browser's own cookie removal processes [all or nothing]), you can keep whatever ones you actually specify. The comment about it reporting everything back can also be turned off easily. Quote Link to comment Share on other sites More sharing options...
johnoo Posted May 3, 2020 Author Report Share Posted May 3, 2020 Thanks, I'll give it a try Quote Link to comment Share on other sites More sharing options...
