madboy33 Posted November 13, 2003 Report Share Posted November 13, 2003 Hi folks i a have just installed XP pro and have a problem in device managerwhat is it?I know about the scanner, so dont worry about that one Link to comment Share on other sites More sharing options...
Chris Posted November 13, 2003 Report Share Posted November 13, 2003 Smart Media?A little slot for a card from a camera?Do you have a card reader?...or the motherboard can support one. Link to comment Share on other sites More sharing options...
madboy33 Posted November 13, 2003 Author Report Share Posted November 13, 2003 No Camera installed or card reader Link to comment Share on other sites More sharing options...
christmascracker Posted November 13, 2003 Report Share Posted November 13, 2003 Have a read here http://www.sysopt.com/forum/showthread.php?threadid=138524 Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 madboy delete yellow ? and restart,smbus is to do with the nforce drivers. Link to comment Share on other sites More sharing options...
madboy33 Posted November 13, 2003 Author Report Share Posted November 13, 2003 Uninstalled it ellas and restarted and the wizard came back saying found new hardware etc etcIts back there Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 madboy look here http://www.nvidia.com/object/nforce_udp_winxp_2.45.html its defo part of the nforce drivers,what version you using. Link to comment Share on other sites More sharing options...
christmascracker Posted November 13, 2003 Report Share Posted November 13, 2003 As in the link I gave you it's to do with the chipset drivers Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 yeah its a chipset driver not smart media ;) Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 madboy go to device manager,then smbus,click update driver and browse to the smbus folder as shown in the pic attachment and it should install the drivers.hang on I will do more pics for you. Link to comment Share on other sites More sharing options...
Chris Posted November 13, 2003 Report Share Posted November 13, 2003 gfhfghfghgfhghg Link to comment Share on other sites More sharing options...
Boris Posted November 13, 2003 Report Share Posted November 13, 2003 What order did you do your install in ?XP Pro + then straight away SP1 ? :o ellas does 3 posts while i'm typing this ? :o Link to comment Share on other sites More sharing options...
Boris Posted November 13, 2003 Report Share Posted November 13, 2003 gfhfghfghgfhghgI know what you mean ! :lol: Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 sorry trying to find it in d/mangler Link to comment Share on other sites More sharing options...
madboy33 Posted November 13, 2003 Author Report Share Posted November 13, 2003 ok ok STOPMe being a silly billy forgot to load the chipset driversDOOOOOOOOOOHWhat am i Yes an Idiot thats what i am Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 :lol: how the hell are you up and running then,madboy what can I say :wacko: Link to comment Share on other sites More sharing options...
madboy33 Posted November 13, 2003 Author Report Share Posted November 13, 2003 Windows XP must have loaded some sort of Generic driver i supposeDont ask me ellasLOL Link to comment Share on other sites More sharing options...
Guest ellas Posted November 13, 2003 Report Share Posted November 13, 2003 yes it does,but thats why your getting the yellows,make sure you have sp1 installed before you install the 3.13 nforce drivers. Link to comment Share on other sites More sharing options...
madboy33 Posted November 13, 2003 Author Report Share Posted November 13, 2003 SP1 is installed and new chipset drivers now installedGuess what No Yellow Question MarkNow for the scanner :( :( :( Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted November 15, 2003 Report Share Posted November 15, 2003 This topic has now been resolved and subsequently closed.If you wish to add a reply, please contact an administrator or moderator to reopen the topic. Link to comment Share on other sites More sharing options...
