Damo Posted February 14, 2004 Report Share Posted February 14, 2004 Just got Mandrake Linux (Off Craig!! :P) but I'm completely lost with it, managed to install it on my empty partition, but when booting into linux and it runs through its checks but come up with 'Failed' at 'Bringing up interface eth0', I'm pressuming it's something to do with my Ethernet card in my laptop, then another line comes up 'Starting ALSA version 0.9.0rc8' and it just hangs on that, nothing else happens so I can't even get into linux!Any ideas before I go back to XP! :o Quote Link to comment Share on other sites More sharing options...
nellie2 Posted February 14, 2004 Report Share Posted February 14, 2004 I should give Redhat a shout if I were you.... he'll be able to put you right!! Quote Link to comment Share on other sites More sharing options...
Chris Posted February 14, 2004 Report Share Posted February 14, 2004 You got a ASUS A7V8X motherboard?with 'Failed' at 'Bringing up interface eth0', I'm pressuming it's something to do with my Ethernet card in my laptopYeah, you have not entered your ISP deatils yet, username, password so it cannot connect! Quote Link to comment Share on other sites More sharing options...
Damo Posted February 14, 2004 Author Report Share Posted February 14, 2004 Ok, i've managed to get into linux by using the interactive boot up and bypassing the eth0 and ASLA options so I now have no sound, I'm guessing it's problems with the drivers? Quote Link to comment Share on other sites More sharing options...
Damo Posted February 14, 2004 Author Report Share Posted February 14, 2004 I know I really should go to a linux forum, but hey I'm commited to this place!How do I get a cd to autoplay? is it as simple as in windows? Quote Link to comment Share on other sites More sharing options...
Chris Posted February 14, 2004 Report Share Posted February 14, 2004 What type of CD is it? Quote Link to comment Share on other sites More sharing options...
Damo Posted February 14, 2004 Author Report Share Posted February 14, 2004 Its the supplementry applications cds, but also music cds wont autoplay (Not that I can hear them anyway!) Quote Link to comment Share on other sites More sharing options...
Chris Posted February 15, 2004 Report Share Posted February 15, 2004 Did you know that Autoplay has a patent?Look in the Mandrake Conrol Centre! Quote Link to comment Share on other sites More sharing options...
Damo Posted February 15, 2004 Author Report Share Posted February 15, 2004 cheerz because that helps me get it running! :P :D Quote Link to comment Share on other sites More sharing options...
Chris Posted February 19, 2004 Report Share Posted February 19, 2004 Ummmm resolved or not?and I have something for you to try with your sound. Quote Link to comment Share on other sites More sharing options...
