madboy33 Posted February 15, 2004 Report Share Posted February 15, 2004 Hi alli am having problems with the PC again, It worked fine this morning, Turned it on tonight and then it just kept restarting. I then looked in event viewer and saw that SMC (sygate firewall ) was causing the problems and i uninstalled that.I thought i would then turn off "Auto Restart" if there was a system failure and got the message listed below (see screen shot)any ideas thanks Quote Link to comment Share on other sites More sharing options...
Chris Posted February 15, 2004 Report Share Posted February 15, 2004 Increase the initial page file size. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 call me thick here but it is above that Quote Link to comment Share on other sites More sharing options...
Chris Posted February 15, 2004 Report Share Posted February 15, 2004 System Managed hmmmm!Did you click yes or no? Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 erm sorry little confused, it was set like that Quote Link to comment Share on other sites More sharing options...
Boris Posted February 15, 2004 Report Share Posted February 15, 2004 i've never touched mine and it looks like this Quote Link to comment Share on other sites More sharing options...
nellie2 Posted February 15, 2004 Report Share Posted February 15, 2004 do you want to see mine too?? Untouched like Boris's Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 ohso what do i set mine to then folks512DDR ram XP2200 40gb HDD and 20gb Slave Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 well it should be ok if its system set,heres a link to optimise the paging file http://www.msfn.org/articles.php?action=show&id=28 madboy your not setting it in system mechanic are you. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 Hi ellasno i binned system mechanic since last format Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 it still does not tell you what to set it to ellas Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 well why are you getting the error when its system set,madboy do you have 2 h/drives Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 yep got 2 hard drives Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 madboy this is mine on 2 harddrives Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 by the way this was set by system mechanic 4 :) Quote Link to comment Share on other sites More sharing options...
nellie2 Posted February 15, 2004 Report Share Posted February 15, 2004 I found this about paging file sizes. It is for W2k but the settings reasoning behind the size should be the same for XPhttp://web.ukonline.co.uk/cook/Pagefile.htm Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 heres the xp one http://www.microsoft.com/WindowsXP/expertz...es/03june16.asp Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 Split the page file over two or more physical drives. If you have two or more physical drives (not just two or more partitions on a single physical drive), splitting the page file over each drive can improve performance because it means Windows XP can extract data from each drive's page file simultaneously. For example, if your current initial page file size is 384 MB, then you'd set up a page file on drive with a 192-MB initial size, and another page file on a second drive with a 192-MB initial size. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 ellas is that on the same system as me and you bought at the time? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 not on that system at the minute,running 3 at the minute :D ,but its set the exact same way,same ram as this one. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 madboy not sure why your getting these problems,the nforce 1 has been rock solid for me. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 okits not a good idea for me to put the swap file on my Slave HDD as that is only a 5200rpm and my master is 7200rpm Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 makes no difference mine are different speeds. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted February 15, 2004 Author Report Share Posted February 15, 2004 ok so can someone teach/tell me how to change the swap file to a different drive then? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 15, 2004 Report Share Posted February 15, 2004 its easy just go in system properties,advanced and performance then set,click on the h/drive and set a pagefile. Quote Link to comment Share on other sites More sharing options...
