serious problem here
you did do as the prince said did you madboy,
RESOLUTION
NOTE: Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
To resolve this issue, disable the script-debugging and script-error-notification options. To do this, follow these steps:
Start Internet Explorer.
On the Tools menu, click Internet Options.
Click the Advanced tab.
Click to select the Disable script debugging check box.
Click to clear the Display a notification about every script error check box.
Click Apply, and then click OK.
ok here are the errors
1
A runtime error has occured
Do you wish to debug?
Line 61
Error:"Symwinopen" is undefined
2
Line 49
Error: "Access is denied"
Thats the 2 errors, i cannot do a print screen for some reason
heeeeeeeeeeeeeeelp
Madboy
Ive had the same problem....I get one or two runtime error pop ups to close down before I can open the page........
It started just before AVG found a trojan on the hard drive (backdoor fraggle)....It showed up after that large AVG reboot update about a week ago....
Ive done a system restore to the start of the month..after deleting the later restore points, because the trojan replicates from the windows system files ...Plus Im a bit dubious about registry editing....
It worked for a few days ....now its back.....AVG does not find the trojan
I downloaded the newest versions of java and vb runtime....just in-case something had been deleted in error....this has not worked either
Also I get the same results on the link you gave earlier
