Boris Posted March 24, 2004 Report Share Posted March 24, 2004 Now available.Upgrade from :-http://www.firetrust.com/products/pro/upgrade.php Quote Link to comment Share on other sites More sharing options...
Boris Posted March 24, 2004 Author Report Share Posted March 24, 2004 Its got new "learning" spam tools ! and colour coded headers now :o Quote Link to comment Share on other sites More sharing options...
andsome Posted March 25, 2004 Report Share Posted March 25, 2004 This of course is the paid for version isn't it? Quote Link to comment Share on other sites More sharing options...
Boris Posted March 25, 2004 Author Report Share Posted March 25, 2004 Naturally ! :rolleyes: Quote Link to comment Share on other sites More sharing options...
andsome Posted March 26, 2004 Report Share Posted March 26, 2004 Naturally ! :rolleyes:The Beta version that you sent to me is doing the job find. It ain't broke so I won't fix it. Quote Link to comment Share on other sites More sharing options...
popeye Posted March 26, 2004 Report Share Posted March 26, 2004 I'm as tight fisted as you andsome :lol: the free version is fine. :rolleyes: Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 26, 2004 Report Share Posted March 26, 2004 I must admit... I paid for Mailwasher and it was £13 well spent in my opinion. Quote Link to comment Share on other sites More sharing options...
andsome Posted March 27, 2004 Report Share Posted March 27, 2004 As I said, the free Beta version supplied to me by Boris is fine and I see no need to change. A completely different kettle of fish however is Diskeeper. Yes the free version did a grand job, but it's the extras in the paid for version that are well worth while. I have mine set to run continuously in the background. Every so often a little icon appears at the bottom of the screen, and if I hover the pointer over it, it tells me that the Diskeeper engine is active. With Pentium 4, 2.4 Gig processor, I can detect no slow down. Both hard drives are always at 100% the biggest surprise however is with a boot time defrag. I set this to occur about once a month, and for the next few days the computer is supersonic. It does a scan disc and then defrags the boot up area. You would not believe the extra performance. It is well worth about £19.http://consumer.execsoft.com/diskeeper/req...ents.asp?RId=50Diskeeper Home Edition 8.0for Windows 95, 98, ME & XP Home = $29.95 - Download EditionDiskeeper Professional Edition 8.0for Win 2k & XP Pro = $45.95 - Download Edition Quote Link to comment Share on other sites More sharing options...
Boris Posted March 27, 2004 Author Report Share Posted March 27, 2004 Cheaper than paying for the full version Diskeeper is this combination :D free Diskeeper Lite for full and fast on-demand defragmenting of your drivesfree Buzzsaw for on-the-fly defragmenting. http://www.dirms.com/free PageDefragfor defragmenting your paging fileshttp://www.sysinternals.com/ntw2k/freeware/pagedefrag.shtmlBuzzsawThis program runs at idle priority so you can continue working without Buzzsaw using your valuable CPU time. It watches the drive for modified files and waits approximately 60 seconds before defragmentation begins. It waits, because you may be downloading a file, etc. and there is no need to defragment the file if it is going to be modified again shortly. It runs minimized on the task bar. Version 2.0 decreases I/O issues by only defragmenting when the disk is greater than 95% idle.PageDefragWhen you direct PageDefrag to defragment, the next time the system boots it will attempt to do so. Immediately after CHKDSK examines your hard drives PageDefrag uses the standard file defragmentation APIs to defragment the files. As it processes each file PageDefrag will print on the boot-time startup screen the file name and its success at defragmenting it. If it is successful at reducing the fragmentation it will tell you the number of clusters the file started with and the number it consists of after the defragmentation. Quote Link to comment Share on other sites More sharing options...
