Boris Posted March 25, 2003 Report Share Posted March 25, 2003 I use Slimbrowser all the time but I have 1 complaint....It occasionally sees windows as pop-ups and kills them when it shouldn't do!Other than that it is excellent :)ShirlIt identifies potential pop-ups by their timing + appearance.Whenever a popup window is detected, it will be suppressed in a hidden state, while a toolbar icon flashes (with an optional beep). You can manually recover the last popup window by selecting "Recover Last Popup Window" from the menu or toolbar. The last-blocked one should then be brought back.The popup will be permanently killed if it's not manually recovered after a particular time.Do you use the white list facility ? Quote Link to comment Share on other sites More sharing options...
Boris Posted April 15, 2003 Report Share Posted April 15, 2003 Version 3.51 releasedFix skin bug when maximizing Fix bug about changing menu speed Close Tab by middle mouse button Display active tab using different text color Add ability to automatically check for new version Quote Link to comment Share on other sites More sharing options...
Guest Shirley_Crabtree Posted April 21, 2003 Report Share Posted April 21, 2003 Version 3.52 released today.Add support for alt key to access menu. Save last open pages at exit Udpated shortcut key documentation. Add Norwegian language file Cheers.Shirl. Quote Link to comment Share on other sites More sharing options...
Tankus Posted April 21, 2003 Report Share Posted April 21, 2003 Since Big Shirls given it the thumbs up ...think Ill have a pop.....v3.52 Quote Link to comment Share on other sites More sharing options...
Tankus Posted April 21, 2003 Report Share Posted April 21, 2003 ooeerr ...................several more lines on the top......pretty icons.... ...and my coppernic search has disappeared....Umm..... anybody checked for spyware ?Need to play with it for a while....Love the page tabs. Quote Link to comment Share on other sites More sharing options...
Boris Posted April 21, 2003 Report Share Posted April 21, 2003 TankusNo spyware as far as i can ascertain.Mine's exactly the same using 3.52 as 3.51 was ! Quote Link to comment Share on other sites More sharing options...
Tankus Posted April 21, 2003 Report Share Posted April 21, 2003 nice..... used something similar with an added links and search bar a fair while ago ...and it was loaded... Quote Link to comment Share on other sites More sharing options...
Boris Posted April 21, 2003 Report Share Posted April 21, 2003 Was that AvantBrowser (with the UCmore toolbar enabled ?) Quote Link to comment Share on other sites More sharing options...
Tankus Posted April 21, 2003 Report Share Posted April 21, 2003 Still use avant on my O2 XDA ....think it was called common name or something like it ?These tabs are very good.....I like the multiple loading of pages...gonna keep it ...nice one .. Boris Quote Link to comment Share on other sites More sharing options...
Boris Posted April 22, 2003 Report Share Posted April 22, 2003 It seems that 3.52 had a few bugs :( - so they've issued a new release 3.52b. :) Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted April 22, 2003 Report Share Posted April 22, 2003 Thanks Boris......(I've already updated mine actually but I thought I would wait for you..... :) ) Quote Link to comment Share on other sites More sharing options...
Guest he he :-)™ Posted April 22, 2003 Report Share Posted April 22, 2003 It seems that 3.52 had a few bugs :( - so they've issued a new release 3.52b. :)they should make you slimbrowser moderator aswell :lol: :lol: Quote Link to comment Share on other sites More sharing options...
Boris Posted April 22, 2003 Report Share Posted April 22, 2003 Thanks Boris......(I've already updated mine actually but I thought I would wait for you..... :) )Sorry for the delay - just got back home again. Been to York + back (420miles) and then up to Gloucester tonight to see a pre-release showing of "Welcome to Collinwood" - quirky !; a bit surreal ?; but absolutely hilarious in places ! Ever imagined George Clooney as a tattooed Rabbi in a wheelchair ? :lol: Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted April 23, 2003 Report Share Posted April 23, 2003 George Clooney!!.............dribble. Quote Link to comment Share on other sites More sharing options...
Boris Posted April 23, 2003 Report Share Posted April 23, 2003 .............dribble.He was in a wheelchair - but he did have full control over all his facilities ! Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted April 23, 2003 Report Share Posted April 23, 2003 Who needs to be vertical!!! :lol: Quote Link to comment Share on other sites More sharing options...
Boris Posted May 6, 2003 Report Share Posted May 6, 2003 V 3.53 is now availableAdds option not to display icon in the favorites menu to reduce popup delay Adds proxy switcher (Old users need to customize the toolbar to see the newly added toolbar button). Adds link extractor (tools->web robots->link extractor) to extract all matching links out of a web page. from :- http://www.flashpeak.com/sbrowser/download.htm Quote Link to comment Share on other sites More sharing options...
Guest Shirley_Crabtree Posted May 7, 2003 Report Share Posted May 7, 2003 Pah... I got the 3.53 reminder this afternoon but I didn't think the update warranted a post as there really is nothing worth shouting about.Cheers.Shirl. Quote Link to comment Share on other sites More sharing options...
