Burn a BIN without a CUE using NERO
Guest ellas
Guest ellas
You've downloaded a *.BIN file, but there was no *.CUE file associated and you still want to burn the *.BIN file using Nero
Your options are:
1) Create yourself a *.CUE
2) Convert the *.BIN to an *.ISO
3) OR use Nero to burn without the *.CUE file!!!
Yes, that's possible... just follow these steps and you will be sorted. No need for *.CUE files anymore
Ok, here we go...
1) Start Nero
2) File -> Burn Image
3) Browse to the *.BIN file that you want to burn and open it
4) A window saying "Foreign Image Settings" will open
5) Check the settings. They should be as followed:
* Type of image: leave it to Data Mode 1
* Select the Raw Data check box
Note ->> The block size will change automatically from 2048 to 2352
* Leave Image Header and Image Trailer unchanged and set to 0
* Leave "Scrambled" and "Swapped" check boxes unchecked
6) Click on burn!
or get winiso and convert ''bin to iso''
then burn the iso with nero
new-iso-open(then select iso)-write
sorry lost the link to the forum I got it off,no doubt boris will hunt it down though :D
http://www.undergroundhub.com/detail.php?i...cb2a664466fdda5
??? :D :D :D Here you are - Boris
The .BIN / .CUE CD image format was made popular by CDRWin software.
Afterwards many programs have started supporting or partially supporting it, including: Nero, BlindWrite, CloneCD, FireBurner.
The .CUE file contains the track layout information, while the .BIN file holds the actual data.
