christmascracker Posted May 15, 2004 Report Share Posted May 15, 2004 As you may know I bought a new graphics card during the week. At the same time I bought a new PSU. The original one that came with the pc 4 months ago was 300w and the new one was a 500w.Everything has been fine all week until yesterday when I ran a HDD health check from floppy. About half way through the drive test a siren started to go off which I presume was the CPU temperature limit thingy that I've set in the bios to go off if it reaches a certain temp. I turned the PC off straight away. The side of the case was really quite warm too (hot!) :( I put the 300w PSU back and ran it again - test finnished and no problems at all.So........ what do I do now? I'll be taking the psu back and getting a refund but do I stick with the original 300w or buy a decent PSU?All advice gratefully appreciated :) The original 300w is a Seasonic and the new 500w was a qtec if thats of any help Link to comment Share on other sites More sharing options...
Agent Smith Posted May 15, 2004 Report Share Posted May 15, 2004 I would have to say that I would be very surprised if simply adding a more powerful psu caused your processor to overheat. At this point I would have to question that you had all the relevant connections plugged in. I would imagine that the newer 500w supply has got several extra plugs than your old one.Did you ensure that once setup, all your fans were running correctly prior to closing the case?Also, is the fan or fans on the new psu running correctly, and because psu's come in different shapes and sizes, when fitted to your case, have you ensured that all the ventilation holes are free to do their job?Mr. M. Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 Yes to all of the above.I heard some where that if it's not a very good quality PSU, that even though it's supposed to be more powerful, it might not be giving out the same power, voltages etc as a better quality one (if that makes sense) Link to comment Share on other sites More sharing options...
Agent Smith Posted May 15, 2004 Report Share Posted May 15, 2004 Yes it does make sense in a strange sort of way.May I ask what you payed for it? I have recently bought one of these Tagan TG480-U01 from here Overclockers ,and although it was £60.00 it is brilliant.It is almost totally silent when running, has more than enough connections to do anything you want, and comes with those nice sticky Velcro things to keep your wires tidy :D :P I would definitely recommend these.Mr. M. Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 It's a q-tec big fan 550w and I paid £30 for it from a local pc shop.Don't know how much you can get them for on the net though - probably cheeperHere it is on their web page http://www.qtec.info/products/product.htm?artnr=13981 Link to comment Share on other sites More sharing options...
Besty Posted May 15, 2004 Report Share Posted May 15, 2004 It says that the fan speed is controlled by the temp is the temp control working properly Link to comment Share on other sites More sharing options...
Agent Smith Posted May 15, 2004 Report Share Posted May 15, 2004 :( I have just found a 550w dual fan q-tec for £20.00 online. It seems to be a higher model than yours.Mr. M. Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 Mmm, well serves me right - as the saying goes, you get what you pay for. :( So the next question is what is the best make? Enermax, antec, vantec, thermaltake. Just had a look at your Tagan - looks good - if looks are anything to go by :) Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 before you rush out and buy a psu are you sure you have enough cooling in your system,any case fans? underpowered psu's often cause crashes and not psu overheating,I would investigate futher before replacing the psu,plus what have you set it to in the bios and does your mobo not support monitoring i.e software like asus probe. Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 before you rush out and buy a psu are you sure you have enough cooling in your system,any case fans? underpowered psu's often cause crashes and not psu overheating,I would investigate futher before replacing the psu,plus what have you set it to in the bios and does your mobo not support monitoring i.e software like asus probe.Yes, I've got a case fan. I'm not getting any crashes and everything is ticking along ok. CPU temp at the mo is 48° MB is 31°It's set to 66° in the bios. Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 66 bit low,max for a athlon is 90,maybe the extra heat outside took it over that.all though I should say if it gets to 90 it fries :D Link to comment Share on other sites More sharing options...
Andy-2004 Posted May 15, 2004 Report Share Posted May 15, 2004 Slightly off topic but if you wana test what the minium juice you system needs.....Look Here Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 nice read here about cpu temps http://forums.windrivers.com/showthread.php?t=27724 Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 66 bit low,max for a athlon is 90,maybe the extra heat outside took it over that.all though I should say if it gets to 90 it fries :DIt's a 3.2 P.4 :) Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 should be ok for 70%, you may be right about the psu,who knows computers are funny things :D a new psu wont do any harm. Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 Slightly off topic but if you wana test what the minium juice you system needs.....Look HereAccording to that I need 414w, but when I bought it new it only had a 300w one and I havn't added anything other than a case fan and changed the graphics card from a GFX 5200 to a GFX 5900 Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 only way to test is put it under load,stick a game in and see how it copes. Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 only way to test is put it under load,stick a game in and see how it copes.It's fine playing games, temp goes up to about 54/56° but everything works ok. Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 so you have only had 1 warning,maybe its a glitch in the bios,its just software after all,I would only worry if you were having frequent crashes,IMHO the psu seems fine. Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 so you have only had 1 warning,maybe its a glitch in the bios,its just software after all,I would only worry if you were having frequent crashes,IMHO the psu seems fine.Well, I put the 550w psu in a couple of days ago, ran the disk check yesterday and got the warning. Put the 300w psu in and ran it again, everything ok. Just to check I put the 500w back in and ran it and it happened again. (hope your following this ok, I'm confusing myself here :D) Put the 300w back in and ran it and everything fine. Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 yeah I am confused :D so you bought the bigger psu and installed already must read posts properly,so your saying the new 550 crashes :teehee: Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 yeah I am confused :D so you bought the bigger psu and installed already must read posts properly,so your saying the new 550 crashes :teehee:Yep, well not crash but when I run the HDD disk check then I get the warning siren With the 300w psu I dont :) Link to comment Share on other sites More sharing options...
Guest ellas Posted May 15, 2004 Report Share Posted May 15, 2004 ah I see,no idea whats causing it :D Link to comment Share on other sites More sharing options...
christmascracker Posted May 15, 2004 Author Report Share Posted May 15, 2004 ah I see,no idea whats causing it :DNope - only the 500w - daft isn't it :) Link to comment Share on other sites More sharing options...
Boris Posted May 15, 2004 Report Share Posted May 15, 2004 Just for info - I've fitted over a dozen of these QTec 550W Gold Twin Fan PSU's in the last 12 months. On a new build I now usually remove the standard cheap 300/350W PSU which comes with the case and put one of these in.Although they're obviously not proper "550W" rated - they're more than enough for any normal use and well worth the £20-22 I usually pay for them at Fairs.Good build quality. Not had a duff one yet :D Link to comment Share on other sites More sharing options...
