mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 to see if it is still in the registry run regedit and go to edit > find and enter toplistcity then delete it then press f3/ delete till it finds no more entries for it Link to comment Share on other sites More sharing options...
Guest ellas Posted January 2, 2003 Report Share Posted January 2, 2003 have you still got regcleaner if so have a look under options to show hidden uninstall items and hidden s/ware and reg entries. Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Delete that reg file now, To make sure system restore is off go start > control panel> sytem > system restore tab> put a tick in 'turn off system restore on all drives' that will get rid of all restore points then once the system is cleaned we can turn it back on Link to comment Share on other sites More sharing options...
Guest ellas Posted January 2, 2003 Report Share Posted January 2, 2003 mark2 I think its about time you did remote assistance,are you on xp :) Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 I am on my 1ghz celly with XP but would need a tutorial to use R A, never tried it No one has trusted me enough :P :P Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 OK no Viruses show up in the scan now ? Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Don't try to reinstall NAV at the moment, in case it all goes wrong there. We really need to search the registry to ceck for all refernces to NAV before we try to reinstall it, I've never been successful with Norton uninstalling itself. Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Time to close down your unneeded auto starting programs can you do another statup list for me to look at? Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Ok go to start > run > msconfig >enterthen general tab and put a dot in selective start up Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Then take the tick out of the boxes next to each of thesereg = regedit /s "C:\Documents and Settings\me\reg.regNvCplDaemon = RUNDLL32.EXE NvQTwk,NvCplDaemon initializeWCOLOREAL = "C:\Program Files\COMPAQ\Coloreal\coloreal.exe"CPQEASYACC = C:\Program Files\Compaq\Easy Access Button Support\StartEAK.exeNeroCheck = C:\WINDOWS\system32\NeroCheck.exeTkBellExe = C:\Program Files\Common Files\Real\Update_OB\evntsvc.exe -osbootsrmclean = C:\Cpqs\Scom\srmclean.exeyou could also disable the messenger ones too and use programs to launch it when you want itI'm not sure what logon loader is so you can probably disable that too Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 you will have to reboot for these changes to take effect, so press the exit without restart button when done unless the A/V scan has finished.when you reboot you will have a message 'you are using the system configuration utility' put a tick in the 'do not show this message again' box and it won't annoy you next time :D Reboot once the A/V scan has finished ;) Link to comment Share on other sites More sharing options...
Guest ellas Posted January 2, 2003 Report Share Posted January 2, 2003 TKbellEXe will come back as soon as you use r/player again,best to install f/wall and stop it that way. Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Once rebooted let it settle then run regcleaner to get rid of the dross. Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 There are 2 files in the recycle bin one was infected one not checked delete both these relate to spyware and defo not needed Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Have you rebooted now , is the system quicker loading ? Link to comment Share on other sites More sharing options...
Guest ellas Posted January 2, 2003 Report Share Posted January 2, 2003 have you both got messanger. Link to comment Share on other sites More sharing options...
Guest ellas Posted January 2, 2003 Report Share Posted January 2, 2003 if so add mark2 to your contacts,then on the righy hand side is ask for remote assistance and ask mark2 to accept. Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Not too bad now, there are a couple of processes still running not needed works calreminder is one was that there in msconfig? Link to comment Share on other sites More sharing options...
Guest ellas Posted January 2, 2003 Report Share Posted January 2, 2003 ok go for it. Link to comment Share on other sites More sharing options...
Guest ellas Posted January 2, 2003 Report Share Posted January 2, 2003 is your messanger working redacted. Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 System now working quicker, running reg cleaner thenreenabling sys restore Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 niow going to try RA :o Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 Update now shutdown unnneeded services via RA and cannot see any more nasties lurkin there :D :D :D Link to comment Share on other sites More sharing options...
mark2 Posted January 2, 2003 Report Share Posted January 2, 2003 And you weren't nervous that I might tell you something that would break your compl :o :o , I was :D :D Link to comment Share on other sites More sharing options...
Guest CalamityJane Posted January 3, 2003 Report Share Posted January 3, 2003 :D redacted :D That is great news! Just wanted to say I have been following this thread, along with others, in the background and you had some excellent help. Plus your willingness to "stick with it" and posting results & questions was most admirable and you should be commended too!I think it has been very educational for anyone who has read it - so you have probably all helped others!!Good work, everyone B) Link to comment Share on other sites More sharing options...
