mark2 Posted January 3, 2003 Report Share Posted January 3, 2003 Just one thing to be wary of with 2 a/v on the system don't have them running as resident at the same time,as they may clash, only have one set to start with windows and use the other as a back up scan as you did using Gladiator. Next thing we need you to get running is your f/wall. ;) Link to comment Share on other sites More sharing options...
Randy_Bell Posted January 3, 2003 Report Share Posted January 3, 2003 naaa, i trusted you....... :D more GOOD news as well NAV is now installed and working properly, so i gues the virus that screwed it up has now gone for shaw!!!1 :D :DThat's GREAT news, now with NAV and TH resident, you'll hopefully have powerful protection and won't get infected ever again: just be sure to keep both products updated. If you're especially paranoid like me, you can d/l daily updates to NAV from here: http://securityresponse.symantec.com/avcen...r/download.html (the daily intelligent updater virus defs are usually available before noon Pacific time of every weekday). TH update notices get posted to dslreports security forum and of course to TH forum -- then make sure you have your TH settings according to this pic I posted earlier: (1) automatically remove trojans tells TH to instantly kill any detected trojan servers in memory without prompting you, which doesn't give the malware any time to do its dirty work of altering the registry or disabling your AV and firewall; (2) shutdown protection creates a randomly named process in your windows temp directory which acts as a "watchdog" to alert you if any malware tries to surreptitiously shutdown the resident TH Guard; (3) load on startup is what you want TH Guard to do, so you have protection from the moment you boot into windows; (4) enabled is of course the state you want to have TH in. Good luck, you sound well on your way to healthy clean computing and you're to be commended for hanging in there and getting your system cleaned up. ;) Link to comment Share on other sites More sharing options...
mark2 Posted January 3, 2003 Report Share Posted January 3, 2003 This one appears to be sorted now then, (hope i haven't spoken too soon) :huh: Link to comment Share on other sites More sharing options...
Guest ellas Posted January 3, 2003 Report Share Posted January 3, 2003 mark2 what are you going to do with all this free time :lol: Link to comment Share on other sites More sharing options...
mark2 Posted January 3, 2003 Report Share Posted January 3, 2003 maybe an early night now and again or watch some telly even! nahh to the last option :D Link to comment Share on other sites More sharing options...
mark2 Posted January 4, 2003 Report Share Posted January 4, 2003 Was beginning to wonder if you'd got more problems :( . have you got your firewall sorted now ?keep all your security apps up to date too. :rolleyes: Link to comment Share on other sites More sharing options...
madboy33 Posted January 4, 2003 Report Share Posted January 4, 2003 this must have been the longest thread of all time, i was watching this one go and go ad gowell done to all those who made a contributionmadboy33 Link to comment Share on other sites More sharing options...
