pwp Posted June 24, 2004 Report Share Posted June 24, 2004 i don't know if it's because i'm leaving my machine on 24/7but since i installed folding @ home i have been having a few problems.i have a black box that shadows the cursor that madboy has mentioned.my desktop has frozen but not all at once the application seemed to go downone by one till nothing would work.a reboot sorted it.this morning it started again when replying on the forum clicked the show allon the emotions and it froze up. tried to shut it in task manager but it would not open so i logged off and back onand all ok again fingers crossed.the only new thing i've loaded is f@h is anybody else having probs. Quote Link to comment Share on other sites More sharing options...
Gagaman Posted June 24, 2004 Report Share Posted June 24, 2004 I'm folding quite some time now... never had a problem with it.Maybe shut down the folding for a couple of days, to see if folding is causing it.edit:*Sounds more like some virus or so??!! :huh: Quote Link to comment Share on other sites More sharing options...
andsome Posted June 24, 2004 Report Share Posted June 24, 2004 No problems with the folding program whatsoever. Quote Link to comment Share on other sites More sharing options...
bvw Posted June 24, 2004 Report Share Posted June 24, 2004 I get the black box effect and you have to keep an eye on your Restore Points in XP, as Andsome said.Other than that no problems :) Quote Link to comment Share on other sites More sharing options...
Tony Posted June 24, 2004 Report Share Posted June 24, 2004 HiI am getting the same problems as you are, since installing folding at home, so at the moment unless i can find away of sorting it all out and making my system stable again, it looks like i will uninstalling it.My PC has always been on 24/7 so i know it is nothing to do with that.CheersTony Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 24, 2004 Report Share Posted June 24, 2004 Your Pc may have been on 24/7 before but not running at 100 %,I think that frequent reboots, I.e once in the morning, once at night,Would give you fresh memory and in theory fix any problems Quote Link to comment Share on other sites More sharing options...
pwp Posted June 24, 2004 Author Report Share Posted June 24, 2004 thanks for the replies will monitor it for a bit longer and see how it goes.i am pretty sure its not a virus as i've used panda, a2, have avg and runspybot, adaware, spywareblaster the black box effect is definitely something to do with folding asit was reported before i loaded f@h and i didn't have it. the black box appeared as soon as i installed f@h.you posted as i was replying Andy will do that and see how it goes. Quote Link to comment Share on other sites More sharing options...
Gagaman Posted June 24, 2004 Report Share Posted June 24, 2004 This is the place where folding guru's come together...Maybe you can post it there.Folding forum Quote Link to comment Share on other sites More sharing options...
pwp Posted June 24, 2004 Author Report Share Posted June 24, 2004 gagamanthanks for the link will look into it.cheers :D Quote Link to comment Share on other sites More sharing options...
Gagaman Posted June 24, 2004 Report Share Posted June 24, 2004 You're welcome. :) Let me known if and how you solved the issue. Quote Link to comment Share on other sites More sharing options...
