[RESOLVED]-Win XP Pro SP1a Problem
After installing Windows XP Professional, I joined my PC to the Windows 2003 Domain. I could login without any problem.
After that, I decided to install Service Pack 1a, and it installed successfully. But the problem now, I can't login to my PC anymore (both domain and local). It keeps restarting after I enter my username and password. Weird.......
Anyone can help me ?????
I can't find any solution to your problem... there doesn't seem to be anything here about it.
Can you log into your admin acct in safe mode? Perhaps it may be best to take SP1a off for now and just keep SP1 on there...... but hang on for a little while before you do anything, someone else may have more of an idea about this problem
Just had another thought, if you can boot into Windows under safe mode you could disable the 'automatic restart on system failure' feature, this would allow you to troubleshoot the problem.
Right click My Computer > Properties > Advanced > Startup and Recovery Settings then uncheck the radio button that says automatic restart.
Thanks for the comments guys.... :D
Yap, you're right nellie2 ! I can logon to my XP using Administrator account in Safe Mode. I've follow your direction to disable the 'automatic restart on system failure' feature. I try to login back to my XP. But wow.....it doesn't restart anymore, but a BLUE SCREEN appearing with a STOP MESSAGE. wallbash
It said :
STOP: 0000007E (0XC0000005,0XF32E6509,0XF7AFC9E0,0XF7AFC6E0)
Unfortunately, I don't have a SP1 installer even when I try to find it in Microsoft's website.
Is it an HCL problem between a fresh XP and SP1a XP ? Confusing....... :shutup:
You may find these links useful...
http://www.theeldergeek.com/stop_error_messages.htm
http://www.microsoft.com/technet/treeview/...md_stp_tnvo.asp
http://aumha.org/win5/kbestop.htm
http://www.updatexp.com/stop-messages.html
Very detailed, but they have explainations for all stop codes. Look up yours, and you may find the problem.
Ya....lastly I know that there's a problem on Hardware Compatibility. I've change my Video Adapter and my Sound Card, and try to re-install WinXP and SP1a. There's the same problem. So, I think the problem is with my Motherboard compatibility with SP1a, of course BIOS version too.
After I upgrade my BIOS to a newer version, it's solved. I can logon to my WinXP SP1a smoothly.
Thanks guys......
