Andy-2004 Posted September 28, 2004 Report Share Posted September 28, 2004 basically i cant get it to work,its connected right, and the light is on...constantly,it shows up in device manager, ive tryed removing it and lettign windows reinstall,none of the above works...help! Quote Link to comment Share on other sites More sharing options...
madboy33 Posted September 28, 2004 Report Share Posted September 28, 2004 sounds like its on its way out then Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted September 28, 2004 Author Report Share Posted September 28, 2004 aww crap, it has never worked since i changed case, or reformatted or somthing, cant remember, but i have never needed it till noware there any disk formatting programes that i can boot from CD? Quote Link to comment Share on other sites More sharing options...
expertec Posted September 28, 2004 Report Share Posted September 28, 2004 If the light is on constantly, the data cable is the wrong way round. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 28, 2004 Report Share Posted September 28, 2004 Check again that the cable is connected the right way round.Often, a constantly on light is a sign that the cable is wrong either at the M/B or the drive end. Don't forget to check both ends :) Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 28, 2004 Report Share Posted September 28, 2004 Ooooops! Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted September 28, 2004 Author Report Share Posted September 28, 2004 you mean the connector is in upside down, or the m/b end is at the floopy end? Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 28, 2004 Report Share Posted September 28, 2004 Could be any of those. Connector may be upside down at M/B end or drive end or it could be back to front.. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 28, 2004 Report Share Posted September 28, 2004 Split end of cable should be connected to FDD.If you have a 2 FDD connector at one end of the cable - use the end one Quote Link to comment Share on other sites More sharing options...
