Scarecrow Man Posted October 21, 2004 Report Share Posted October 21, 2004 I have a very noisey computer. The PSU and CPU fans were making noise. I cleaned the inside with some air, but the PSU fan still hums quite loudly. It is directly attached to the PSU and I don'y think it comes off without opening the PSU. Will I need a new PSU or can I replace this fan?Bestec BPS-1203SBcouldn't find any info for it though. Quote Link to comment Share on other sites More sharing options...
Boris Posted October 21, 2004 Report Share Posted October 21, 2004 IF you do open it be very careful about the residual charge ! Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted October 21, 2004 Author Report Share Posted October 21, 2004 That's why I DONT want to open it. Quote Link to comment Share on other sites More sharing options...
christmascracker Posted October 21, 2004 Report Share Posted October 21, 2004 If that was me I would just go out and buy another one........not worth the risk. You not got a spare one lying around? Quote Link to comment Share on other sites More sharing options...
trackrat Posted October 21, 2004 Report Share Posted October 21, 2004 PSU's are not meant to be taken apart.When they are switched off they hold a charge in the capacitors for a time. So do not take a risk go out and buy a new one. Quote Link to comment Share on other sites More sharing options...
Boris Posted October 21, 2004 Report Share Posted October 21, 2004 Found this here http://www.hothardware.com/forum/messagevi...2&enterthread=yIf left disconnected COMPLETELY, a 330uF 200V electrolytic capacitor will stay charged enough to hurt for weeks on end. However, in modern ATX PSUs there are two things that keep this from happening when you unplug the AC power cord but keep it plugged into the motherboard: the +5Vsb line and the trickle-discharge resistors. The +5Vsb line is one of the wires going to the motherboard, it is a 5V power supply that stays on even if the computer is "off" if it's still plugged in and is used for Wake On LAN and the front panel power switch circuitry. The trickle-discharge resistors are each around 150-750 kilohm resistors placed across the capacitors in the PSU to keep the curious from killing themselves quite as easily, they lower the discharge time to around an hour I believe. However, by far the best way to discharge the capacitors fully is to unplug the system (but leave the PSU connected to the motherboard) and then try to turn it on. You should see hear the HDDs start to spin up and see the fans whir, maybe the lights on the keyboard will flash and then it's discharged. Do it two or three times just to be certain it's finished. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted October 22, 2004 Author Report Share Posted October 22, 2004 Thanks Boris. I know all about electricity, and I must say;Do not pee on an electric fence! Quote Link to comment Share on other sites More sharing options...
