Chris Posted December 16, 2004 Report Share Posted December 16, 2004 I'm after an External USB HDD 200GB + :DContenders:Maxtor OneTouch II USBOR:WD Dual Option - Media Center 250 GB 8-in-1 memory card readerWhat yo think. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted December 16, 2004 Report Share Posted December 16, 2004 I like WD. It's what I used for my XBOX. (I should add that it is VERY loud) but that Maxtor drive looks very nice. Quote Link to comment Share on other sites More sharing options...
prctr Posted December 16, 2004 Report Share Posted December 16, 2004 I have had considerably more luck with Maxtor than with WD. For what its worth. Quote Link to comment Share on other sites More sharing options...
djohn Posted December 16, 2004 Report Share Posted December 16, 2004 I use Maxtor drives [internal] and they are whisper quiet. :) Quote Link to comment Share on other sites More sharing options...
Chris Posted December 16, 2004 Author Report Share Posted December 16, 2004 But 8in1 and USB hub is appealing :D Quote Link to comment Share on other sites More sharing options...
bvw Posted December 16, 2004 Report Share Posted December 16, 2004 Again.....I use tool-free enclosures. Get any size hard drive you want, as many as you want, and you can swop them around at will. To open the enclosure takes 5 seconds and to swop drives about 2 minutes. Quote Link to comment Share on other sites More sharing options...
Chris Posted December 16, 2004 Author Report Share Posted December 16, 2004 Again.....I use tool-free enclosures. Get any size hard drive you want, as many as you want, and you can swop them around at will. To open the enclosure takes 5 seconds and to swop drives about 2 minutes.Tooo...Low tech :PNot really into several HDD. Quote Link to comment Share on other sites More sharing options...
bvw Posted December 16, 2004 Report Share Posted December 16, 2004 External USB HDD 200GBI must be missing something.......... :blink: Quote Link to comment Share on other sites More sharing options...
Chris Posted December 16, 2004 Author Report Share Posted December 16, 2004 I mean swapping. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted December 17, 2004 Report Share Posted December 17, 2004 Go with the Maxtor Quote Link to comment Share on other sites More sharing options...
Shirley Crabtree Posted December 17, 2004 Report Share Posted December 17, 2004 Powerless...Your cartoony avatars breast jiggles worry me somewhat....Sod the 1 hour deadline!!! Quote Link to comment Share on other sites More sharing options...
trackrat Posted December 17, 2004 Report Share Posted December 17, 2004 Never had a problem with Maxtor I am using an 80gb in a Belkin external enclosure for my backups. Quote Link to comment Share on other sites More sharing options...
Chris Posted December 17, 2004 Author Report Share Posted December 17, 2004 Errrrr went for the WD instead :oUSB hub and card reader :D won it. Quote Link to comment Share on other sites More sharing options...
