abarbu Posted January 17, 2005 Report Share Posted January 17, 2005 I recently bought a Sony DW-D22A DVD-RW Drive. Because I did not have any connectors free, I unplugged my CD-ROM and connected my new DVD-RW. It worked quite fine. After 4 days I had to reinstall windows XP SP2 (the same as before) but with the DVD instead of the CD. Windows puts it in DMA mode 3 and when I want to write something.... it hangs. If I change the transfer mode to PIO, it is ok but the speed is somenthing like 2x or less. I changed the IDE cable, I put the DVD alone on the IDE cablle. but nothig helped. Any ideeas ? thank you ! Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 17, 2005 Report Share Posted January 17, 2005 I don't understand why you unplugged your DVD writer and replaced it with your DC ROM to re-install SP2.DVD writers will happily read and write CDs so your CD ROM isn't needed now.Try putting your DVD writer bsck, delete the drivers and let Windows find and re-install for you. Quote Link to comment Share on other sites More sharing options...
andsome Posted January 17, 2005 Report Share Posted January 17, 2005 WELCOME to WF. When my CD reader packed up, my local shop replced it with DVD reader. As pops says, it reads DVD's and CD's with no problem at all. Quote Link to comment Share on other sites More sharing options...
abarbu Posted January 17, 2005 Author Report Share Posted January 17, 2005 sorry fot the missunderstanding. when I bought my dvd i replaced my old CD-rom with the DVD-RW and it worked fine. I reinstalled windows XP (with SP2) with the dvd-rw connected (of course) and it was in dma mode 3 and it hangs etc, etc. my problem is that dvd-rw doesn't write any dvd. it simply hangs after neto says "caching of files started". it it is in PIO mode it works fine but extremly slow Quote Link to comment Share on other sites More sharing options...
Boris Posted January 17, 2005 Report Share Posted January 17, 2005 Are you using an IDE 80pin or 40 pin lead ? Quote Link to comment Share on other sites More sharing options...
abarbu Posted January 17, 2005 Author Report Share Posted January 17, 2005 yes, I am using a 80 pin connector cable. I changed it but... no difference. The strange thing is that it worked on my old windows. but after the install... it didn't. so I don't think is a hardware problem. what can I do ? Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 18, 2005 Report Share Posted January 18, 2005 Check to make sure the drivers are listed properly in Device manager... Quote Link to comment Share on other sites More sharing options...
