Guest EyesWideShut Posted April 21, 2003 Report Share Posted April 21, 2003 or simply open Explorer and navigate to Windows/System32 and rename the folder Catroot2 to OldCatroot2. Then try the updates again. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted April 21, 2003 Report Share Posted April 21, 2003 bvw in bristolYOU ARE A STAR MATEFollowed your instructions to the letter and all updates installedMany thanks to all who helped me through this oneELLAS---------------- You have been brillant and thanks for the time and effort you spent in remote assistance with me madboy33p.s. Going to open another thread as cookies not working for some reason in this forum Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted April 22, 2003 Report Share Posted April 22, 2003 nice one bvw in bristol ;) Quote Link to comment Share on other sites More sharing options...
madboy33 Posted April 22, 2003 Report Share Posted April 22, 2003 p.s. The cookies problem was a Forum problem and not my computerJust thought i would clear that up Quote Link to comment Share on other sites More sharing options...
Guest he he :-)™ Posted April 22, 2003 Report Share Posted April 22, 2003 thats why I couldn't get in then... just typed out my responce to your topic and found that you deleted it :( :( :( Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted April 27, 2003 Author Report Share Posted April 27, 2003 OK Folks.......Micro$oft have finally admitted the problem and Microsoft pulls hotfix Q811493Posted by Neobond on 26 Apr 2003 - 18:40 CET | 25 Comments or rather moved it from Critical Updates to Windows XP in Windows Update.Thanks Large for his post in BPN on our forums. Microsoft is revising a security patch for Windows XP systems with Service Pack 1 installed after customers complained that installing the patch slowed their systems to a crawl.Microsoft is working on a revised patch for Windows XP Service Pack 1 and will reissue that patch when it has been completed and fully tested, the Redmond, Washington, software maker said in a revised version of its security bulletin MS03-013 posted late Wednesday.Originally released on April 16, the security bulletin addressed a buffer overrun vulnerability in the Windows kernel, which manages core services for the operating system such as allocating processor time and memory, as well as error handling.Taken from HERE.For the full M$ Link CLICK HERE. ;) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted April 27, 2003 Report Share Posted April 27, 2003 info here http://support.microsoft.com/?kbid=819634 Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted April 27, 2003 Report Share Posted April 27, 2003 not needed with a single user computerMethod 1: Temporarily Remove the 811493 UpdateReview the MS03-013 security bulletin to determine if you should install the 811493 security update in your particular environment. If your level of risk permits you to delay deploying the patch until it is revised and the performance issue is corrected, temporarily remove (uninstall) the patch. For example, if you are the only person who uses your computer, or if all users of your computer are computer administrators (or members of the local administrators group), it is not important that you install this update. For additional information about the scope of the security vulnerability, review the MS03-013 security bulletin. To review the bulletin, visit the following Microsoft Web site: Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted April 28, 2003 Author Report Share Posted April 28, 2003 There's a good read HERE about the problems with the patch.Microsoft Reworks Win XP Patch Update: Windows fix blamed for system slowdowns.Joris Evers and Paul Roberts, IDG News ServiceThursday, April 24, 2003Microsoft is revising a security patch for Windows XP systems with Service Pack 1 installed after customers complained that installing the patch slowed their systems to a crawl. Microsoft is working on a revised patch for Windows XP Service Pack 1 and will reissue that patch when it has been completed and fully tested, the Redmond, Washington, software maker said in a revised version of its security bulletin MS03-013 posted late Wednesday.Originally released on April 16, the security bulletin addressed a buffer overrun vulnerability in the Windows kernel, which manages core services for the operating system such as allocating processor time and memory, as well as error handling.A flaw in the way the kernel passes error messages to a debugger could enable a malicious hacker to take any action on a vulnerable system, such as deleting data, reconfiguring the device or modifying user accounts and privileges, Microsoft said in its advisory.Performance ProblemsSoon after the patch was released, however, Windows XP users began complaining in online forums of performance problems that appeared after the patch was applied.Users reported that Windows XP can take up to ten seconds or even more to start an application after installation of the patch. Removing the patch brings system speed back to normal, Windows XP users wrote in dozens of postings on several online discussion boards.The company received a "small number" of complaints resulting from "special situations" involving the interaction of XP Service Pack 1 and third party applications following the patch, according to Stephen Toulouse, security program manager at Microsoft's Security Response Center. Some users experiencing the problem did not even think a patch could be to blame. "I first blamed my VirusScan, since I had a problem several years ago when VirusScan would run away with my CPU and hog all of the cycles," a high-tech corporate communications consultant in Oakland, California, who asked not to be named, wrote in an e-mail to the IDG News Service. "I had not even considered going to Microsoft tech support.""I've never called Microsoft. Also, I thought maybe some virus was causing it. So I ran the antivirus software I have. I thought maybe that would take care of it," wrote Sandra D., an aspiring author who uses a PC at her home in Pennsylvania.Other users with systems suddenly moving at sluggish speed complained that the phone number for Microsoft's help line is hard to find or costs too much."I attempted to contact the Microsoft help desk, but when I found there was a substantial fee involved, I declined to do it. Also, because my purchase of Windows XP Professional was made as part of a Dell hardware purchase, the Microsoft Web site said I should contact Dell tech support. I did contact Dell, but they said they could not be responsible for this particular problem because it is a Microsoft problem," wrote one reader who heads up a technology management consultancy near Salt Lake City."Microsoft help is usually the very last step I consider. I'm just too overwhelmed by the size and complexity of Microsoft's operating system, Web site, organization, et cetera," wrote Offer P., a home PC user in Israel who was able to restore his system speed to normal after removing the patch. Toulouse, commenting on the user reaction, said Microsoft's free +1-866-PC SAFETY (+1-866-727-2338) help line for virus-related support is also open for calls from users in the U.S. and Canada on issues with security patches. Users outside the U.S. and Canada can find numbers on Microsoft's support Web site, he said. "If anyone is having issues I really want them to call the number for support," Toulouse said. So far Microsoft has had hardly any support calls on this Windows XP performance issue, he said. Patch Still AdvisedIn updating its security bulletin, Microsoft acknowledged those problems, but said that customers running Windows XP Service Pack 1 should still consider applying the flawed patch as protection until a new version is released."Customers are encouraged to review this security bulletin...[and] assess whether their particular environments demand that the patch should be applied immediately or whether their particular level of risk permits delaying deployment of the patch until it is revised and the performance problem corrected," the company said.Customers who restrict access between different users on a computer should install this update, Microsoft said in the end-user version of its bulletin. If the PC is only used by a single user or no passwords or other measures are used to limit access to accounts on the computer, it is not important to install this update, according to the bulletin.In response to the performance issues, Microsoft has lowered the Windows Update ranking for the security patch so it does not automatically install on systems that have the auto-update feature enabled. Also, the Windows Update Web site no longer displays the patch as critical, but as recommended, according to a Microsoft spokesman who asked not to be named. "These steps were taken to give customers the opportunity to evaluate the patch before installing it," the spokesman said. Microsoft is actively involved in finding a solution to the performance problems, in addition to investigating how the faulty patch made it through Microsoft's patch review process, Toulouse said. Microsoft said it will also publish a knowledge base article that describes what environmental factors produce slowdowns when combined with the XP patch and what can be done to reduce the impact of the slowdowns if they occur. That article should be available within the next few days, according to Toulouse. He declined to estimate when an updated patch that resolves the performance issues will be available, however.;) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted April 28, 2003 Report Share Posted April 28, 2003 not seeing any real difference on my 2 machines so I guess I will just leave it on till the revised 1 comes out. Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted April 30, 2003 Author Report Share Posted April 30, 2003 I am leaving it too, until the patch comes out from M$.... :P ;) Quote Link to comment Share on other sites More sharing options...
bvw Posted May 2, 2003 Report Share Posted May 2, 2003 Re-installed Q811493, all appears ok now :) Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted May 29, 2003 Author Report Share Posted May 29, 2003 Update Released...File Name: Q811493_WXP_SP2_x86_ENU.exe - Download Size: 3241 KB - Date Published: 5/28/2003 - Version: 811493A security issue has been identified that could allow an attacker to compromise a computer running Microsoft® Windows® XP and gain complete control over it. An attacker would need the ability to log onto the computer locally to carry out an attack. You can help protect your computer by installing this update from MicrosoftNote: This is the re-release of Q811493, Microsoft originally issued this bulletin on April 16, 2003. Subsequent to that date, Microsoft has received reports of performance problems with the patch from some Windows XP customers. Microsoft has investigated this issue and confirmed that there can be performance problems when the [original] patch is applied to Windows XP Service Pack 1 systems.+ Q815021 XP: Security Update released also ;) Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted May 29, 2003 Author Report Share Posted May 29, 2003 Seems faster....[touchwood] ;) Quote Link to comment Share on other sites More sharing options...
