XP Q811493 Update Problem
  • Replies 63
  • Created
  • Last Reply
Top Posters In This Topic
Click Start, and then click Run. In the Open box, type cmd, and then click OK. At the command prompt, type the following commands, pressing ENTER after each line: net stop cryptsvc
ren %systemroot%\system32\catroot2 oldcatroot2
net start cryptsvc
Type exit to close the command prompt.
Be sure to type the commands carefully.
http://www.pcadvisor.co.uk/index.cfm/go/di...82667/forumid/1
Madboy..this may help you, I'm a bit shattered tonight after coming back from holiday and brain dead ;) but this usually works.
