Problems opening up media files
LaXdAwG
First off my system is ME. I am having a problem playing media files with windows media player, I just get audio and no video. My friend has tried sending me videos that are user created and don't work with other media players that I know of. Is this a common problem with ME? Is there some sort of solution or player known to go around the no video problem?
Hi
Download this tool G SPOT and use it to have a look at the avi file you are having trouble with, it should tell you what codecs you need to view it, it will also give loads of other info about the avi file.
Tony
