Problems with ad-aware and spybot guide
Jayno
Nellie
Just a little snag help
I think you have missed some instructions out of this guide. Towards the end of the section on how to run a scan with Adaware, after opening customisation, you say go to the Advanced button and check the following are ticked green ...
There isn't anything listed .......
Jayno
:rolleyes:
I must be reading it wrong. I still can't see anything. This (xxxx) is where I mean:
Then Click the Advanced Button on the left side to open the Advanced Settings screen. Make sure the following is on with a "green" checkmark:
xxxx
Others are optional to be checked or unchecked.
J
