Alan2273 Posted August 12, 2005 Report Share Posted August 12, 2005 I have 2 computers an AMD 64 3500 running XP home and an Amd 3000 shuttle on which I have taken the plunge and installed Mepis.I would like some suggestions as to a wireless router to connect the two computers and how easy is it to do.Please keep it simple as I am only just starting to learn Mepis. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted August 12, 2005 Report Share Posted August 12, 2005 OK - if you intend to use Ethernet, pretty much any router will do. As for wireless, the equipment you're going to be concerned with is the wireless adapter. See the wiki page at NDISWrapper for instructions and devices known to work.http://ndiswrapper.sourceforge.net/mediawi...x.php/Main_Page Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted August 13, 2005 Author Report Share Posted August 13, 2005 Thanks for that scuzzman, I have never used a router so could you please explain what you said about the wireless adapter or would it be easier to do a wired set up. Quote Link to comment Share on other sites More sharing options...
mark2 Posted August 13, 2005 Report Share Posted August 13, 2005 Hi Alan, a wired connection will be simpler for you (apart from installing the wires) I haven't yet managed to get wireless working with my linux partition :( but the Network cards have always been picked up and installed without a problem. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted August 13, 2005 Author Report Share Posted August 13, 2005 Thanks mark2, the computers are next to one another so the wiring will be no problemSo i just need a router and 2 cat 5 cables as i have LAN connectors on both computers, or have I missed something?.. Quote Link to comment Share on other sites More sharing options...
mark2 Posted August 13, 2005 Report Share Posted August 13, 2005 So i just need a router and 2 cat 5 cables as i have LAN connectors on both computers, or have I missed something?..That's all you need :) However have a quick look here for some valid advice# An "OkeyDokey 4000 Router" might be £10 cheaper than a "good" brand, but that extra £10 could buy you a whole lot more. Not only are we more likely to have members who have experienced the model and can therefore help you with configuration, but access to manufacturer support and firmware updates are also far more likely. We will help if we can, but hands on experience is better.# Consider your future needs. Right now you may need wires-only access for 2 computers, but with prices of wireless routers (which usually include a 4 port wired switch) falling ever closer to those of their wires-only counterparts, you might be better off spending a few more pennies now and future proofing yourself. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted August 13, 2005 Author Report Share Posted August 13, 2005 Cheers mark2 I will have a read of that now. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted August 14, 2005 Report Share Posted August 14, 2005 There are also multiple stickies in the Networking board by homecomputeraide and myself on networking. Quote Link to comment Share on other sites More sharing options...
