fdisk help
Brent
Which version of Windows do you want to install?
If W98 (SE) then you need a boot floppy. If XP then you need to have the machine able to boot from CD then all formatting and installing can be done from the XP CD.
Does this help.
Make sure A: is the first boot device in cmos. Boot up with a 98 bootdisk. Choose to start with or without cdrom support--at this point it doesn't matter. At the a:\> prompt type fdisk and enter and Y to large disk support, if asked.
You can choose option 4 from the menu to view the partition information. Option 3 will allow you to remove any existing partitions. For a fresh installation you'll probably want all the old partitions deleted. When that's done, choose option 1 to create the partition. It'll scan the drive and then ask if you want to allocate all the space to a single partition. For simplicity answer Y. Then it'll do the scan again. When it's done, exit fdisk and reboot again with the bootdisk.
If you plan on doing the OS installation then from the menu choose 'cdrom support'. Pay attention to the last few lines that load prior to the final a:\> prompt as that will tell you the cdrom drive letter (some bootdisks temporarily change the letter). Then at the prompt type format c: and enter. When it's done it'll ask about a label. Just hit enter as only a weenie wants to name his hard drive.
Then with the 98 cd in the cdrom type X:\setup and enter, where X: is the cdrom drive letter indicated when you booted up. That should start the windows installation.
well i booted up the pc with xp disk in the pc and i started installing xp...but the only thing wrong with that xp goes to this pc that iam on right now...so i cant update it or anything...so what i want to do is go back to 98 on that pc...can a make bootup diskettee with xp for 98
