D4\/!d Posted August 22, 2014 Report Share Posted August 22, 2014 There are a couple of programs I use that require Java.I have both version 7 and version 8 installed....dunno why.Java is disabled on my browsers.Do I need version 8?The programs seem to complain about version 8.Is version 8 aimed at win8 users. I use Win 7x64.I am thinking of un-installling Java 8v11x64.What do you think... Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted August 23, 2014 Author Report Share Posted August 23, 2014 You only need one Java version. How do these programs "complain" about JRE 8? JRE 8 works perfectly on my Win 7. For x64 you may need to install both 32-bit and 64-bit builds. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted August 23, 2014 Report Share Posted August 23, 2014 Hello Pat, The complaint is an error message that says: You are using the wrong Java version. Use an original Sun Java. Start the program anyway? Your Version: Runtime Version 1.8.0_11-b12It all works OK. It's just the tiresome error message at launch. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted August 24, 2014 Author Report Share Posted August 24, 2014 I would update to the latest JRE version 8u20, then ask the company that develops these programs about the message. "Sun Java" has been a long time ago, it is now "Oracle Java" since a number of years. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 27, 2015 Author Report Share Posted May 27, 2015 Java SE 7 update 79&80 released (for those who need / want to remain on JRE7).Release Notes:http://www.oracle.com/technetwork/java/javase/7u-relnotes-515228.htmlDownload:http://www.oracle.com/technetwork/java/javase/downloads/jre7-downloads-1880261.htmlhttps://www.java.com...load/manual.jspMake sure to uncheck any unwanted software offers during the installation.Verifying Java Version: http://www.java.com/...d/installed.jspHow do I test whether Java is working on my computer? : http://www.java.com/...ad/testjava.jsp Sorry, this update was actually released at the same time as the JRE8 update above. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 23, 2015 Author Report Share Posted October 23, 2015 Java SE 8 update 65 / 66 released.Release Notes:http://www.oracle.com/technetwork/java/javase/8u65-relnotes-2687063.htmlhttp://www.oracle.com/technetwork/java/javase/8u66-relnotes-2692847.htmlDownload:https://www.java.com/en/download/manual.jsphttp://www.oracle.com/technetwork/java/javase/downloads/jre8-downloads-2133155.htmlMake sure to uncheck any unwanted software offers during the installation.Verifying Java Version: http://www.java.com/en/download/installed.jspHow do I test whether Java is working on my computer? : http://www.java.com/en/download/testjava.jspNote 1: Java 8 is not certified for Windows XP; see http://www.oracle.com/technetwork/java/javase/certconfig-2095354.html Note 2: Java 7 is no longer updated; see http://java.com/en/download/faq/java_7.xml Note 3: earlier Java versions (e.g. JRE 8u51) may need to be uninstalled manually. Quote Link to comment Share on other sites More sharing options...
