WinHelpPlz3 Posted June 17, 2006 Report Share Posted June 17, 2006 Is there any way that I can convert or update from a 32bit system to a 64bit system?Thanks Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 17, 2006 Report Share Posted June 17, 2006 64 bit is a wholly different technology compared with 32 bit requiring different hardware and software. They are not interchangeable. Quote Link to comment Share on other sites More sharing options...
benb Posted June 17, 2006 Report Share Posted June 17, 2006 IIRC XP 32-bit cannot upgrade to x64. Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted June 17, 2006 Report Share Posted June 17, 2006 To convert from 32 bit to 64 bitBuy and fit new 64 bit CPU capable MOBOInstall new 64 bit CPUFormat hard driveInstall 64 bit operating systemNoting that XP64 is a compromise and to get full advantage of 64 bit technology you'll need Vista. Which currently opens up a whole new area of driver and software compatibility problems.64 bit will be great, but IMHO, it isn't yet fully realised technology and most people who go for it are doing it to get one up on the Joneses, rather than for any significant real time benefit. Quote Link to comment Share on other sites More sharing options...
WinHelpPlz3 Posted June 18, 2006 Author Report Share Posted June 18, 2006 Thank you :) Quote Link to comment Share on other sites More sharing options...
