r4may Posted July 29, 2006 Report Share Posted July 29, 2006 I've always built my own PC except for a early Tandy TR80, which I then opened up and added to and upgraded to take a floppy (5.25") instead of the Cassette tape loader. Quote Link to comment Share on other sites More sharing options...
Gandalph Posted July 29, 2006 Author Report Share Posted July 29, 2006 Asus TA-210 Midi Tower, (Black with silver front trim)450 Watt Power supply,Asus A85N-E ATX Motherboard,1GB Kingston PC3200 RAM, (Motherboard takes 4GB Max)Seagate Barracuda 200GB HDD,Asus 16X CD and DVD +/- RW Re-writer,AMD Athlon 64 3500+ Socket 939,Geforce 7600GS PCI-E Graphics Card,Logitech Classic keyboard (Black),Logitech optical Wheel-mouse (Black),Time taken to build from scratch one hour 40 minutes and it's running like a dream. :DI was out most of yesterday and missed this. It takes me half of that time to find my way into all the packaging and get the right page in the multilingual Motherboard manual. Well done. Next time I want one building I shall head for the borders.You could probably add another twenty minutes to go through the jumper settings on the board, take out the HDD and set the jumper and the same with the CD/DVD drive. The actual time stated was from taking the side off the case and starting on the power supply etc,. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted July 29, 2006 Report Share Posted July 29, 2006 You guys make it sound so easy I am tempted to have a go - not that I really need a new computer at present. One area of concern is to ensure that any investment is suitable for Vista - perhaps I should wait until Vista is launched and its requirements are better known.Hopefully I will prove incompetent enough to get more than a couple of hours enjoyment from spending two or three hundred pounds. Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted July 29, 2006 Report Share Posted July 29, 2006 CW, I know the top of it is called the IHS; integrated heat spreader.Cheers Daz that's the one Quote Link to comment Share on other sites More sharing options...
