rong Posted September 22, 2006 Report Share Posted September 22, 2006 I think you also need a pong. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 22, 2006 Report Share Posted September 22, 2006 I think you also need a pong.Why have you brought his feet into the topic?? :D Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted September 22, 2006 Report Share Posted September 22, 2006 If you play games can you tell me what your ping is like online ...i need to know this before i sign up..I don't play computer games but I have seen on posts people talking about "ping" and "pinging" and haven't a clue what they are talking about.If you can give me some guidance about what my ping is and how I can find out what it is like I will do my best to help. (That is, if you are being serious!)Yes he was being serious http://en.wikipedia.org/wiki/PingBelow is my ping to WF:C:\Documents and Settings >ping forums.windowsforum.orgPinging forums.windowsforum.org [208.101.35.208] with 32 bytes of data:Reply from 208.101.35.208: bytes=32 time=140ms TTL=49Reply from 208.101.35.208: bytes=32 time=140ms TTL=49Reply from 208.101.35.208: bytes=32 time=139ms TTL=49Reply from 208.101.35.208: bytes=32 time=140ms TTL=49Ping statistics for 208.101.35.208: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 139ms, Maximum = 140ms, Average = 139msI have interleaving on (error correction) which adds between 10 - 40 ms to my ping times but as I'm not an online gamer this doesn't worry me. Quote Link to comment Share on other sites More sharing options...
djohn Posted September 22, 2006 Report Share Posted September 22, 2006 Hello Thos, to do a ping go to 'Start/run' and in the window of the dialogue box type 'cmd' without the quotes. A small DOS window will open with a cursor blinking away. Type the word,pingthen tap the space bar on your keyboard then the following www.windowsforum.orgOr, www.google.comOr, www.bbc.co.ukHit the enter key on your keyboard and it will give results similar to those shown in the post from Rebel. If you want to copy them out to post here then left click on the little C:/ Icon top left of window, select 'edit/sellect all' then 'edit/copy' come back to the forum and right click and paste. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 22, 2006 Report Share Posted September 22, 2006 Microsoft Windows XP [Version 5.1.2600]© Copyright 1985-2001 Microsoft Corp.C:\Documents and Settings\Keith Jones>ping www.windowsforum.orgPinging windowsforum.org [208.101.35.208] with 32 bytes of data:Reply from 208.101.35.208: bytes=32 time=134ms TTL=46Reply from 208.101.35.208: bytes=32 time=126ms TTL=46Reply from 208.101.35.208: bytes=32 time=124ms TTL=46Reply from 208.101.35.208: bytes=32 time=135ms TTL=46Ping statistics for 208.101.35.208: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 124ms, Maximum = 135ms, Average = 129msC:\Documents and Settings\Keith Jones>How does this look? Quote Link to comment Share on other sites More sharing options...
Thos Posted September 22, 2006 Author Report Share Posted September 22, 2006 Microsoft Windows XP [Version 5.1.2600]© Copyright 1985-2001 Microsoft Corp.C:\Documents and Settings\Thomas Noon>ping www.windowsforum.orgPinging windowsforum.org [208.101.35.208] with 32 bytes of data:Reply from 208.101.35.208: bytes=32 time=142ms TTL=52Reply from 208.101.35.208: bytes=32 time=138ms TTL=52Reply from 208.101.35.208: bytes=32 time=140ms TTL=52Reply from 208.101.35.208: bytes=32 time=138ms TTL=52Ping statistics for 208.101.35.208: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 138ms, Maximum = 142ms, Average = 139msC:\Documents and Settings\Thomas Noon>Now iI have done that, will someone tell me what it means and whether it is good or bad. (I hope it is better than andsomes or I will never hear the last of it)Thos. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 22, 2006 Report Share Posted September 22, 2006 I too am puzzled as to what it all means, that's why I went through the process. Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted September 22, 2006 Report Share Posted September 22, 2006 I too am puzzled as to what it all means, that's why I went through the process.Well it just means that the shorter the time in ms it takes to connect to a website the more suited your connection is for online gaming.I am pleasantly surprised to learn that my ping results to WF are only 10 ms than yours andsome and you are on cable with no interleaving.Perhaps my connection wouldn't be as bad for online gaming as I thought it would be! Quote Link to comment Share on other sites More sharing options...
djohn Posted September 22, 2006 Report Share Posted September 22, 2006 Well done guys you got it spot on first time. Pinging a site is one way of checking if its down or not, also looking at the response times in milliseconds gives you some idea of how quick you can access that site. Another useful tool and one that can actually help show where there are any problems or holdups is a 'tracert' Exctly the same as the ping but use the word 'tracert' instead.tracert www.windowsforum.org is what you place in the command window instead of the word 'ping'. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 23, 2006 Report Share Posted September 23, 2006 Are the figures that Thos and me got Good, OK, just about acceptable, or not very brilliant? Quote Link to comment Share on other sites More sharing options...
andsome Posted September 23, 2006 Report Share Posted September 23, 2006 This morning I am getting 126ms to WF, but only 15ms to BBC. Why the massive difference? Quote Link to comment Share on other sites More sharing options...
Thos Posted September 23, 2006 Author Report Share Posted September 23, 2006 Thanks everyone for all of this, especially Curly who gave the explanatory link which I have only just got around to reading.Thos. :) Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted September 23, 2006 Report Share Posted September 23, 2006 This morning I am getting 126ms to WF, but only 15ms to BBC. Why the massive difference?I think it's because the ping (or tracert) time depends on which way your signal travels down the internet and also how busy the replying server is?As the WF server is a shared resource perhaps the ping time is slightly higher than if you were replying to a dedicated server?My ping times to WF always vary but are usually in the 120 - 150 ms range. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 23, 2006 Report Share Posted September 23, 2006 Thanks for the info. I have noticed just recently how painfully slow the forum can be at times. Sometimes it seems to take ages to post etc. No problems elsewhere, the computer just flies along. Quote Link to comment Share on other sites More sharing options...
13thHouR Posted January 17, 2007 Report Share Posted January 17, 2007 For those of you considering migrating over to SKY Broadband, I think I should post my experience of this ISP from hell.An excerpt of a recent article I published.I have Now confirmed that I got slammed (Illegally Migrated from an ISP without authority) by SKY Broadband (Easynet).Basically, I had considered migrating to them, but thought better of it after doing some further background checks . I found there was no change from the old Easynet responses, Fake unbundling dates, poor tech support (As an example It takes you about a week just to get something as simple as DNS settings from them. As DNS is too advanced of an issue for the script reading level 1 tech support there).So within 12 hours of Signing up………..I cancelled again (Did not even give them time to progress the order to the next level team).However from what I have been able to find out, a member of the SKY Broadband sales team went back in about 7 hours later and reinstated the order to the BT Wholesale to carry out the Migration (Conveniently their Login ID has been removed form their system). At this point they had no contract, I had been fully refunded and was quite happy staying on nice friendly Aceinternet.co.ukOr so I thought…………….Read the full article here: http://r-force.org/modules.php?name=News&a...r=1&thold=0It's a real eye opener on how SKY do business. Quote Link to comment Share on other sites More sharing options...
Thos Posted January 17, 2007 Author Report Share Posted January 17, 2007 Interesting, but it runs counter to my experience with Sky. I migrated from Wanadoo in precisely one month and have been very satisfied with my package since.Thos. Quote Link to comment Share on other sites More sharing options...
